חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת עם תמיכה ב Full HD עם מנוע
תאור:
Dome Full HD IP-camera with tilt and swivel drive DCS-5615 provides high-definition video transmission and compression format H.264. When you connect to the network camera provides broadcast quality video over the Internet.
CCTV High Resolution
Camera DCS-5615 supports Full HD resolution and enables you to capture video in widescreen mode (16:9 aspect ratio), which provides high quality images and greatly simplifies viewing and video surveillance. The included software allows you to view high quality images up to 32 cameras on a single computer screen in real time. The camera is also equipped with a slot for microSD-card, which is used for local backup of important events.
Support for multicast data
To increase bandwidth efficiency while maximizing image quality camera DCS-5615 uses simultaneous video compression formats: MJPEG, MPEG-4 and H.264. When using the H.264 codec receive files small size, which allows for long-term recording and use the device in networks with low bandwidth. MJPEG format provides file integrity, making it ideal for situations which require high image detail. The camera can organize multicast data streams and provide access to video on demand.
Clear image under different viewing angles
Thanks to Pan / Tilt Camera DCS-5615 provides an overview of the vast field from different angles, and 16x digital zoom allows you to bring an area of ​​interest for more information.
Connection flexibility
Digital input (DI) DCS-5615 allows you to connect external devices such as infrared sensors, switches and alarm relays. The camera is also equipped with built-in PoE, simplifying installation and eliminating the need for additional power cables laying.
Detection of tampering attempts housing
Detection attempts effects on the body allow you to place the camera in places where there is a risk of vandalism, such as transportation hubs, schools and reformatories. Camera equipped with an electronic alarm that uses a visual or audible alarm when the position or focus of the camera, as well as blocking or spray painting.
Centralized management via D-ViewCam
Software D-ViewCam ™ D-Link, the supplied allows you to view up to 32 cameras on a single computer screen. Users can set up an automatic notification by e-mail to be instantly informed of unusual activities, to create a recording schedule, as well as motion detection to record directly to your hard drive. Software D-ViewCam ™ also allows you to upload a floor plan of the enterprise and create the layout of the cameras, which greatly simplifies the process of governance.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
