חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת Mini Dome באיכות HD
מאפיינים כללים:
Camera Hardware Profile
• 1/4” 1 megapixel progressive CMOS sensor
• 5 meter IR illumination distance
• Minimum illumination: 0 lux (with IR LED on)
• Built-in microphone and audio out
• 10x digital zoom
• Fixed length: 2.8 mm
• Aperture: F1.8
• Angle of view:
  (H) 75.2°
  (V) 48.2°
  (D) 89.3°
• Minimum object distance: 500 mm
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable privacy masks zones
• Configurable brightness, saturation, contrast, and sharpness
• Configurable motion detection windows
Video Compression
• Simultaneous H.264/MPEG-4/MJPEG format compression
• H.264/MPEG-4 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 800, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176 up to 30 fps recording*
• 4:3 - 1024 x 768, 800 x 600, 640 x 480, 480 x 360,  320 x 240 up to 30 fps recording*
Audio Support
• G.711: 64 kbps
• AAC: 64 kbps
External Device Interfaces
• 10/100 BASE-TX Fast Ethernet port with 802.3af PoE support
• microSD/SDHC card slot**
Network Protocols
• IPv6
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP / HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP / RTSP/ RTCP
• IP filtering
• QoS
• CoS
• Multicast
• IGMP
• ONVIF compliant
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
System Requirements for Web Interface
• Browsers: Internet Explorer, Firefox, Chrome
Event Management
• Motion/Sound detection
• Event notification and uploading of snapshots &  video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive via web browser
• Configuration interface accessible via web browser
Mobile Support
• mydlink Lite/mydlink+ mobile app for iPhone™, iPad™, and Android™ mobile devices
D-ViewCam™ System Requirements
• Operating System: Microsoft Windows 8/7/Vista/XP
• Web browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Remote management/control of up to 32 cameras
• Viewing of up to 32 cameras on one screen
• Supports all management functions in web interface
• Scheduled motion triggered, or manual recording options
נתונים פיזיים
 Weight
• 130g Without Stand
External Power Adapter
• Input: 100 to 240 V AC, 50/60 Hz
• Output:  5 V DC, 1.2 A
Power Consumption
• 3.5 W
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC Class B
• C-Tick
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
