חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת באיכות HD ותקן אלחוטי AC
מאפיינים כללים:
Camera Hardware Profile
• 1/4” Megapixel progressive CMOS sensor
• 8 meter IR illumination distance
• Minimum illumination: 0 lux with IR LED on
• Built-in Infrared-Cut Removable (ICR) Filter module
• 10x digital zoom
• Focal length: 2.4 mm
• Aperture: F2.0
• Angle of view:
  • (H) 98°
  • (V) 52°
  • (D) 115°
• Minimum object distance: 200 mm
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable privacy mask zones
• Configurable shutter speed, brightness, saturation, contrast, and sharpness
Video Compression
• Simultaneous H.264/MJPEG format compression
• H.264 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 720, 800 x 448, 640 x 360, 480 x 272, 320 x 176 up to 30 fps recording
• 4:3 - 960 x 720, 800 x 592, 640 x 480, 480 x 352, 320 x 240 up to 30 fps recording
Audio Support
• AAC
• G.711
External Device Interfaces
• 802.11a/b/g/n/ac wireless with WEP/WPA/WPA2 support
• 10/100 BASE-TX Fast Ethernet port
• microSD card slot2
• Audio in and out jacks
Network Protocols
• IPv6
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP / HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP / RTSP/ RTCP
• IP filtering
• QoS
• CoS
• Multicast
• IGMP
• ONVIF compliant
Wi-Fi Features
• Operates over 2.4 GHz and 5 GHz frequency bands
• Dual-band 1T1R mode supports a maximum data rate of 433 Mbps (PHY rate) using 80 MHz bandwidth
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
System Management
System Requirements for Web Interface
• Browser: Internet Explorer, Firefox, Safari, Chrome
Event Management
• Motion/sound detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive via web browser
• Configuration interface accessible via web browser Mobile Support
• Supports mydlink Lite/mydlink+ mobile apps for iOS and Android mobile devices
D-ViewCam™ System Requirements
• Operating System: Microsoft Windows 8/7/Vista/XP
• Web Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Remote management/control of up to 32 cameras
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
• Supports all management functions in web interface
נתונים פיזיים
Weight
• Without stand: 115 g ± 5%
• Stand: 45 g ± 5%
Power
• 5 V DC, 1.2 A through external power adapter
• External Power Adapter Input: 100 to 240 V AC, 50/60 Hz
Power Consumption
• 3.5 watts max.
Temperature
• Operating: 0 to 40 °C (32 to 104 °F)
• Storage: -20 to 70 °C (-4 to 158 °F)
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC class B
• C-Tick
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
