חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת קווית Cube באיכות HD
תאור:
The DCS-2103/UPA HD Cube Network Camera is a IP surveillance camera that lets you monitor an area 24 hours a day. It helps you keep an eye on your home or office, even when you’re away.
Camera Surveillance For Home & Office
The DCS-2103/UPA is a unique and versatile surveillance solution for your home or small office. Unlike a traditional webcam, the DCS-2103/UPA is a complete system with a built-in CPU and web server that transmits high quality video images for security and surveillance. Simple installation and an intuitive web-based interface offer easy integration with your Ethernet network. The DCS-2103/UPA also comes with remote monitoring and motion detection features for a complete and cost-effective home security solution.
ePTZ For Surveying Regions Of Interest
The ePTZ feature allows users to select a target region for close-up viewing simply by clicking on the video feed displayed within their browser. ePTZ makes use of the camera’s mexapixel resolution to survey a large area effortlessly. Since ePTZ requires no moving parts, there is no need to worry about the camera having mechanical failures.
Built for Versatility
The DCS-2103/UPA comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. A passive infrared (PIR) sensor detects motion near the camera, allowing it to automatically record video and send you a notification when motion is detected. A built-in microphone and speaker allow for 2-way communication, which is ideal for use in entryways or for caretaker applications. It even includes PoE connectivity, allowing it to be placed easily in places that do not have readily available power outlets.
A Complete, Expandable Surveillance Solution
The DCS-2103/UPA is a self-sufficient surveillance solution, capable of recording snapshots and video to a MicroSD card without requiring a PC or network storage device. If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
