חיפוש מהיר
תכונות המוצר:
מצלמת מעקב להשגחה על תינוקות עם מנוע
תאור:
Watch over your child anytime, anywhere with the DCS-850L Wi-Fi Baby Camera. Pan/tilt functionality lets you move the camera remotely; monitor an entire playroom with ease from your mobile device! With night vision, temperature monitoring, sound and motion detection, 2-way audio, notifications and more, the DCS-850L keeps you connected to your family.
Peace of Mind, Anywhere, Anytime
The Wi-Fi Baby Camera is specially designed to make it easy for you to care for your baby. Its versatile all-day monitoring turns on night vision automatically when it gets dark, giving you a clear picture day or night so you can keep an eye on things anytime. Receive notifications when sound, motion, or a temperature change is detected. Not only can you see and hear your infant, but you can also comfort them with one of five gentle lullabies or even the sound of your voice through two-way audio.*
It’s perfect for use in the home, or even when you’re away; it’s mydlink-enabled, which means that you can access your camera remotely over the Internet on your PC or mobile device. Check on your baby while in the office, and take snapshots and video of your little one and save them to your mobile device.
Pan/Tilt for Corner to Corner Coverage
Unlike most baby monitors, the Wi-Fi Baby Camera can pivot up, down, left, and right at your command, giving you the ability to watch over a large room effortlessly. Whisper quiet motors let you move the camera’s view without waking your sleeping child.
Perfectly Portable for Instant Monitoring Anywhere
You can take the Wi-Fi Baby Camera with you when traveling with your child, even when there is no available Internet connection. Just connect your mobile device to the Wi-Fi Baby Camera’s wireless network for instant local monitoring, making it perfect for family vacations or just visiting friends. You can even connect it to an external USB battery** for total portability.
Super Simple to Use
Getting started is a snap; the free mydlink Baby app for iPhone, iPad, and Android mobile devices not only guides you step by step through the setup process, but also gives you an easy to use interface for all the advanced features of the Wi-Fi Baby Camera. Check on your baby at a glance, pinch to zoom in and out with ease, or play one of five gentle lullabies to soothe your child. You can even take snapshots and video clips and save them directly to your mobile device!
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
