חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת בצורת כיפה באיכות Full HD עם תמיכה ב PoE ו WDR
תאור:
External vandal dome network 2MP Full HD-Camera DCS-4602EV / UPA with support WDR, PoE, and night shooting is the ideal solution for creating a system of professional high-definition video and security of small, medium and large enterprises. The camera is equipped with a highly sensitive megapixel CMOS-sensor with progressive scan technology and supports WDR, which allows to obtain excellent image quality in all conditions. With its robust design "all in one" camera is ideally suited to meet the challenges of video surveillance systems and requires no additional accessories.
Streaming and recording of high quality
To maximize bandwidth efficiency and improve image quality, DCS-4602EV / UPA compresses video in real time, using codecs H.264 and MJPEG, and supports three separate profiles for transmission of video in real time and record. These features provide a wide range of uses cameras for security purposes, such as monitoring public places to detect incidents and coordinating responses, control of restricted areas, deterring criminal activities or monitoring of the property.
Continuous monitoring
Camera DCS-4602EV / UPA with WDR sensor delivers excellent image quality with uneven lighting that allows the identification of objects, lighted from behind, or to shoot with too bright light. In complete darkness ICR-filter is automatically shifted to the side to use a wide range of light surveillance. Also, the camera DCS-4602EV / UPA is equipped with built-in infrared LEDs enables the camera to conduct surveillance in total darkness at a distance of 20 meters. All this makes the DCS-4602EV / UPA ideal for day and night surveillance.
Reliable management software
Supplied with the camera DCS-4602EV / UPA includes software D-ViewCam - complete package software for video, allowing you to view the image, manage and record up to 32 cameras on a single computer. Video recording and email alerts can be triggered by motion detection, informing administrators of unusual activity.
Flexible connectivity
Camera DCS-4602EV / UPA is equipped with built-in PoE standard 802.3af, simplifies installation by providing the power and LAN connection on one Ethernet-cable and thus eliminates the need for drilling holes and laying additional power cables.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
