DCS-4802EEOL
Vigilance Full HD Outdoor PoE Mini Dome Camera
תאור
The DCS-4802E Vigilance Full HD Outdoor PoE Mini Dome Camera gives you sophisticated surveillance from a pint-sized package. Easy to install and easy to configure, the DCS-4802E mounts to a ceiling or wall for instant coverage of your home or office. It gives you crisp, 1080p HD video day and night, thanks to its built-in night vision and IR illuminators. Built with a weatherproof design, you can even install it outdoors to watch over an entryway or open area.
High-Quality Streaming & Recording
To maximize bandwidth efficiency and improve image quality, the DCS-4802E provides real-time video compression using the H.265, H.264 and MJPEG (DCS-4802E rev. Р’) / H.264 and MJPEG (DCS-4802E rev. A) codecs, and supports two separate profiles for simultaneous video streaming and recording. This versatility enables a wide variety of security applications, such as monitoring public areas to detect incidents and to coordinate responses, enforcing access control to restricted areas, deterring criminal activity, or monitoring inventory.
Continuous Monitoring
The DCS-4802E WDR image enhancement gives you improved image quality in environments with uneven or difficult lighting, so you can identify subjects that are backlit or in brightly lit areas. In low-light situations, the IR cut filter automatically slides out of the way to use all available light. The DCS-4802E also has built-in IR LED illuminators with a 20 meter range, allowing the camera to keep watch even in complete darkness. These features work together to give you a reliable surveillance camera capable of monitoring an area 24 hours a day.
Robust Management Software
The DCS-4802E Vigilance Full HD Outdoor PoE Mini Dome Camera includes D-ViewCam, a complete surveillance software package that enables you to view, manage, and record from up to 32 cameras on a single computer in a central location. Recordings and e-mail alerts can be triggered through motion detection or events triggered by digital input devices, keeping administrators informed of any unusual activity.
Flexible Connectivity
The DCS-4802E has a built-in 802.3af compliant PoE module that simplifies Light Sensor installation by providing power and networking connectivity with a single Camera Lens cable, reducing the need to drill holes or lay additional cabling.
מאפיינים כללים
Device Interfaces
• 10/100Base-TX Ethernet port with PoE (802.3af) Class 2
Camera Hardware Profile
• 1/2.7 2 Megapixel progressive CMOS sensor
• 20 meter IR illumination distance
• Minimum illumination:
  Color (Day Mode), IR LEDs off: 1.0 lux
  B/W (Night Mode), IR LEDs off: 0.5 lux
  B/W (Night Mode), IR LEDs on: 0 lux
• Built-in Infrared-Cut Removable (ICR) Filter module
• 10x digital zoom
• Minimum object distance 0.5 m
• Focal length: 3.6 mm
• Aperture: F1.8
• Angle of view (16:9):
  (H) 88В°
  (V) 50В°
  (D) 97В°
• Adjustment angle (non-motorized):
  Tilt: 75В°
  Pan: 360В°
  Rotation: 360В°
Camera Housing
• IP66 compliant weatherproof housing
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable privacy mask zones
• Configurable exposure time, brightness, saturation, contrast, sharpness
• Wide Dynamic Range (WDR)
• 3D filtering
Video Compression
• Simultaneous H.265/H.264/MJPEG format compression
• H.265/H.264/MJPEG multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1920 x 1080, 1280 x 720, 800 x 448, 640 x 360 up to 30 fps*
• 4:3 - 1440 x 1080, 1280 x 960, 800 x 600, 640 x 480 up to 30 fps*
Network Protocols
• IPv6
• IPv4
• ARP
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP/HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP/RTSP/RTCP
• IP filtering
• Multicast
• CoS
• QoS/DSCP
• SNMP
• ONVIF compliant
• Bonjour
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
System Requirements for Web Interface
• Operating system: Microsoft Windows 10/8/7 or Mac OS X 10.9 or higher
• Browser: Internet Explorer 9, Firefox 12-51, 52 ESR, Chrome 42 or higher, Safari 9 or higher
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive
• Configuration interface accessible via web browser
D-ViewCam System Requirements
• Operating System:
  - 32-bit: Windows 7 (SP1)/8
  - 64-bit: Windows Server 2008 R2/Server 2012/7 (SP1)/8/10
• Web Browser: Internet Explorer 8 or higher
• Protocol: Standard TCP/IP
D-ViewCam Software Functions
• Remote management/control of up to 32 cameras
• Supports all management functions provided in the web interface
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
Physical Parameters
Weight
• 370 grams В± 5%
Dimensions
• Diameter: 113 mm
• Height: 85 mm
Power
• 12 V DC / 1.5 A power adapter
• IEEE 802.3af PoE Class 2
Power Consumption
• 3.68 watts В± 5%
Temperature
• Operating: -40В° to 50В°C
• Storage: -20В° to 70В°C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE (Class A)
• CE LVD
• ICES
• FCC (Class A)
• RCM
* Frame rates when streaming video may vary depending on network conditions and method used.
תקנים
הורדות
איורים
DCS-4802E/Ax
מראה מקדימה
מראה מימין
מראה משמאל
דף מידע
ראה גם
