תאור
Low-Light Surveillance
The D-Link® DCS-3410 Fixed Network Camera is a versatile monitoring solution for installations that require the ability to record in low-light situations. The low lux enables you to record anytime, day or night, with minimal lighting. Along with the additional options available including features such as simultaneous MPEG-4 & MJPEG streaming, a BNC connector, digital I/O ports, PoE support, and support for optional low light accessories, the DCS-3410 provides the versatility needed for professional surveillance applications.
Low-light Video Capture
The DCS-3410 features 0.3 Lux light sensitivity for low-light monitoring, enabling you to capture video anytime, day or night. Additionally, you can attach a CS mount standard lens such as an auto-iris lens, IR LED lens, or a night vision illuminator, to record video in environments with little or no light. The DCS-3410 also comes with a 12V interface to provide power for an optional LED illumination.
Multiple Streaming
The DCS-3410 supports simultaneous dual-streaming of MPEG-4 and MJPEG to provide both high quality and bandwidth efficient compression formats. MJPEG delivers greater file integrity, making it ideal for detailed monitoring situations. MPEG-4 video has smaller file sizes, making it more useful for extended recording periods or for use in low bandwidth networks.
Flexible Connectivity
The DCS-3410 has a BNC connector for video transmission to a standard video security monitor or CCTV video server. It also includes digital ports (2 input & 1 output) allowing connectivity to external devices such as IR sensors, switches, and alarm relays. The DCS-3410 also comes with a RS-485 interface, providing connectivity to an optional Pan/Tilt enclosure, which effectively adds pan/tilt functionality to the DCS-3410. Additionally, a 12V interface provides power for an optional LED illuminator.
3GPP Mobile Surveillance
Support for 3GPP Mobile Surveillance1 allows you to view a live video feed from your compatible Internet-ready mobile phone with a 3GPP player installed. This extends your monitoring capability without requiring the use of a computer, allowing you to check your camera’s video feed while on-the-go.
Additional Features
The DCS-3410 comes with a built-in microphone and audio port allowing 2-way audio communication2 when an external speaker is connected. The DCS-3410 also comes with a built-in Samba client for NAS so there is no need for a direct connection to a PC or any other hardware or software to capture and transfer images. Equipped with 802.3af Power over Ethernet (PoE) support3, the DCS-3410 can receive both power and data over a single Ethernet cable, enabling you to place this camera in locations without a power outlet.
Convenient Camera Management
The included D-Link D-ViewCam™ 2.0 software enables you to manage up to 32 network cameras, set e-mail alert notifications, set recording schedules, and trigger motion detection to record directly to your hard drive. D-ViewCam 2.0 also allows you to upload a floor plan of your business and create a realistic layout of where your cameras are located, further simplifying the management process.
מאפיינים כללים
General Specifications |
Audio |
Video Resolution |
Network Connectivity |
General I/O |
Environmental |
Certifications |
Physical Specifications | |||||||||||||||||||||||||||||||||||||||
LEDs |
Power Input |
Dimensions (W x D x H) |
Weight |
Software | |||||||||||||||||||||||||||||||||||||||
Video Algorithm Supported |
Security |
Remote Management |
Network Protocols |
Minimum Requirements | |||||||||||||||||||||||||||||||||||||||
To View |
To Run D-ViewCam™ Software |
Warranty Information | |||||||||||||||||||||||||||||||||||||||
Warranty |
Ordering Information | |||||||||||||||||||||||||||||||||||||||
Part Number |
DCS-3410 |
