USE EXISTING WIRING TO CREATE A HOME NETWORK
D-Link’s PowerLine HD Ethernet Adapter is an ideal solution for connecting computers, HD media players, game consoles, and network attached storage devices to your home network. Simply connect one adapter to your router and plug it into an existing power outlet to turn every other power outlet in your home into a possible network connection - just plug in additional adapters as needed*.
THE ULTIMATE IN MULTIMEDIA STREAMING
D-Link’s Powerline HD Ethernet Adapter is ideal for connecting an Ethernet-enabled digital media device such as a Tivo® or Slingbox™ to your network and the Internet. D-Link PowerLine HD Ethernet Adapters also enable you to connect gaming consoles like the Xbox 360®, PlayStation® 3, or Nintento Wii™ to the Internet. To top it all off, QoS support helps prioritize your data, enabling smooth video streaming and lag-free gaming.
CONVENIENTLY CONNECT
Connect multiple devices in the farthest corners of your home by attaching a switch or wireless access point to a D-Link PowerLine HD Ethernet Adapter*. Plus, D-Link’s PowerLine HD Ethernet Adapters implement 3DES encryption for securing your connection to help keep your data safe from intruders.
With hassle-free plug & play installation, D-Link’s PowerLine HD Ethernet Adapter (DHP-300) and Starter Kit (DHP-301) are an ideal solution to create a wall-to-wall home network.
WHAT THIS PRODUCT DOES
D-Link’s PowerLine HD Ethernet Adapter (DHP-300) and Starter Kit (DHP-301) take advantage of your home’s existing electrical wiring to create or extend a network*. Turn every power outlet into a possible network connection to connect computers, digital media players, and game consoles throughout your home*.
EXPERIENCE DIGITAL ENTERTAINMENT
Uses your home’s existing electrical wiring*.
Stream HD media content across your network.
Up to 200Mbps** throughput.
Connect computers, game consoles, and multimedia devices to the Internet.
Plugs into existing power outlets*.
QoS support helps prioritize Internet traffic.
Extend your wireless LAN by connecting an access point to achieve stronger wireless signals in remote areas.
Supports enhanced network security.
Simple Plug-and-Play installation.
