| Technical Specifications |
Data Rates* |
Downstream: Up to 24Mbps |
Upstream: Up to 3.5Mbps | |
Compliance |
TR-067 Interop Performance |
TR-069 Compliant with ACS | |
ADSL Standards |
Multi-mode |
Full-rate ANSI T1.413 Issue 2 |
ITU-T G.992.1 (G.dmt) Annex A/C/I |
ITU-T G.992.2 (G.lite) Annex A/C |
ITU-T G.994.1 (G.hs) | |
ADSL2 Standards |
ITU-T G.992.3 (G.dmt.bis) Annex A/J/K/L/M |
ITU-T G.992.4 (G.lite.bis) Annex A | |
ADSL2+ Standards |
ITU-T G.992.5 Annex A/L/M | |
ATM/PPP Protocols |
ATM Forum UNI3.1/4.0 PVC - Up to 8 PVCs |
PPP over ATM |
PPP over Ethernet | |
Network Protocols and Features |
Ethernet to ADSL Self-Learning Transparent Bridging |
Internet Control Message Protocol (ICMP) |
IP Static Routing |
Routing Information Protocol (RIP, RIPv2) |
Network Address Translation (NAT) |
Virtual Server, Port Forwarding |
NAT ALGs: MSN Messenger, FTP, CUSEEME, H323_Q931 (Netmeeting etc.), H323_RAS, ICQ, etc. |
Dynamic Host Configuration Protocol (DHCP) |
DNS Relay, DDNS |
IGMP Proxy |
Simple Network Time Protocol (SNTP) | |
Firewall |
Built-in NAT |
MAC Filtering |
Packet Filtering |
Stateful Packet Inspection (SPI) |
Denial of Service Prevention (DoS) |
DMZ | |
VPN |
Multiple IPSec/PPTP/L2TP Pass-through | |
QoS |
Port-based Priority |
802.1p (0~7) Priority | |
Wireless |
64/128-bit WEP |
Multi-SSID |
WPA™-PSK |
WPA2™-PSK/Mixed Mode |
WDS |
802.1x RADIUS |
EAP |
802.11e WLAN QoS | |
Configuration and Management |
Web-based GUI Configuration |
ADSL/ADSL2/ADSL2+ Manual Selection and Auto Fallback |
Auto VPI/VCI Detection |
Configuration Backup and Restore | |
Ports |
ADSL Port (RJ-11) |
4 10/100 Ethernet Port (RJ-45) | |
LEDs |
Power |
Status |
DSL |
WLAN |
LAN |
Internet | |
Temperature |
Operating: 32°F to 104°F (0°C to 40°C) |
Storage: -4°F to 149°F (-20°C to 65°C) | |
Humidity |
5% to 95% Non-condensing | |
Certifications |
FCC Class B |
CE |
RoHS |
CSA | |
Dimensions |
Item (WxDxH): 7.7” x 5.8” x 1.3” |
Packaging (WxDxH): 10.8” x 8.2” x 2.7” | |
Weight |
Item: 0.7 lbs |
Packaging: 2.4 lbs | |
Warranty |
Minimum System Requirements |
Subscription with DSL Internet Service Provider |
Computer with a Network Interface Card | |
Package Contents |
ADSL2/2+ Modem with Wireless Router |
CAT5 Ethernet Cable (RJ-45) |
Telephone Cable (RJ-11) |
Power Adapter |
CD-ROM*** with:
Installation Wizard |
Product Documentation | | |
