חיפוש מהיר
תכונות המוצר:
מתאם אלחוטי PCI Express בתקן אלחוטי AC1200
תאור:
Dual Band Wireless PCI Express Adapter AC1200 DWA-582 provides a high-speed connection to the wireless network with improved quality of signal reception by connecting to that, you can get a secure share photos, files, music, videos, printers, and storage.
Increased speed and enhanced wireless range
DWA-582 adapter allows you to connect to a wireless network at a higher speed and longer distances. Extended range and increased speed guarantees fast and reliable connection anywhere in your home. DWA-582 provides for a home network performance through the use of technology to work in two frequency bands. Check mail and visit Web-sites can be in the 2.4 GHz band, and play games online, use the IP-telephony and watch streaming HD-video - in an interference-free 5 GHz band.
Benefits of PCI Express
PCI Express offers higher bandwidth, increased productivity and allows you to connect the adapter DWA-582 to any computer PCIe slot - x1, x4, x8 or x16. Through the installation of the adapter inside the system space savings, and the antennas are safely tucked away at the back of the unit.
Connecting to the network
DWA-582 provides very high performance. This adapter is designed for use in bigger homes and for users that demand higher networking performance. Using this adapter in conjunction with a wireless router Wireless AC provides maximum performance and allows you to stay connected anywhere in the house. DWA-582 is backward compatible with devices 802.11n / g / b / a.
Reliable protection
DWA-582 supports data encryption WEP, WPA and WPA2, which provides a secure connection to the wireless network of its intrusion. Technology WPS (Wi-Fi Protected Setup) allows you to establish a secure wireless connection with one push of a button in the utility to connect to.
Ease of setup
Quick Setup Wizard provides step by step instructions for installing an adapter that allows you to configure the device without professional assistance. Due to the high performance, reception, signal and security, this adapter is an excellent choice for creating or improving connectivity desktop computers to a wireless network.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
