חיפוש מהיר
תכונות המוצר:
מתאם אלחוטי Rangebooster בתקן 802.11n
מאפיינים כללים:
System Requirements
• Windows XP SP2 or 2000 SP4
• CD-ROM drive
• 20 MB of free hard disk space
• A free USB-port
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• USB 2.0
Frequency band
• From 2412 to 2483.5 MHz
Encoding method
• DSSS, OFDM
Modulation schemes
• DBPSK, DQPSK, DSSS and CCK (BPSK/QPSK/16-QAM/64-QAM/OFDM)
Wireless Speed ​​*
• 802.11g: 6/9/12/18/24/36/48/54 Mbit / s
• 802.11b: 1/2/5.5/11 Mbit / s
• 802.11n: 30/60/90/120/180/240/270/300 Mbit / s
Receiver Sensitivity
(802.11b, PER 8%)
• 11Mbps / s:-89dBm
• 1, 2, 5.5, 11 Mbit / s:-91dBm
(802.11g, PER 10%)
• 6Mbps / s:-90dBm
• 9 Mbit / s:-89dBm
• 12 Mbit / s:-87dBm
• 18 Mbit / s:-85dBm
• 24 Mbit / s:-82dBm
• 36 Mbit / s:-79dBm
• 48 Mbit / s:-74dBm
• 54 Mbit / s:-73dBm
Transmitter output power (typical)
• 18dbm (802.11b)
• 14dbm (802.11g)
• 14dbm (802.11n)
Antenna
• Two built-in antennas
Security
• 64/128-bit WEP-encryption
• Wi-Fi Protected Access (WPA / WPA2)
Operating voltage
• 5 VDC + / - 10%
Power Consumption (802.11n)
• TX: 460mA
• RX: 280mA
Indicator
• Activity
נתונים פיזיים
Dimensions
• 87 x 28 x 12 mm
Operating temperature
• 0 ˚ to 40 ˚ C
Storage temperature
• From -20 ˚ to 65 ˚ C
Operating Humidity
• From 10% to 90% noncondensing
Relative Humidity
• 5% to 95% noncondensing
Certificates
• FCC Class B
• CE
• C-Tick
• IC
* Maximum wireless signal rate derived from IEEE 802.11g standard specifications and 802.11n. 802.11n speeds obtainable when operating in a network with other devices Series RangeBooster N. Data transmission speeds may vary significantly on the speed of wireless connections. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. On the range of your wireless network factors may adversely affect the environment.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
