DAS-3224/E/CEOL EOS
תאור
Description:
Through a network interface uplink-Gigabit Ethernet (GE), IP DSLAM DAS-3224/E/C provides a cost effective solution for direct connection to IP-networks through the Internet router or switch LAN.
IP DSLAM allows providers to arrange for subscribers broadband access networks using existing copper telephone lines. The device supports ADSL/ADSL2/ADSL2 + and advanced IP-based services, including QoS, multicasting and subscriber management. These features help to eliminate bandwidth congestion and provide noise free and efficient transmission of video, voice and data network. Triple Play technology provides simultaneous transmission of content to the demanding bandwidth: voice, video and data - through a single infrastructure. The device supports the aggregation of a series DAS-3224/E/C uplink-channel (association uplink-channel GE into one logical interface). In addition, through option Daisy Chaining, all connected devices can use a single uplink-channel GE.
DAS-3224/E/C supports the restriction and filtering MAC address using MAC-level service. The device also supports one-sided test line (methods SELT) to determine the state line to connect the modem. Bilateral testing of the line (methods DELT) is mainly used for checking the line after installing the modem. This function provides troubleshooting on lines with low productivity. Administration and operations management (OAM) is to ensure control, testing and monitoring. OAM loop-back is used to confirm the integrity of the virtual route or channel between the various nodes in the ATM network.
Web-management interface supports several functions, including monitoring the status in real time. IP DSLAM also allows monitoring and administration from a network management Network Management System.
To ensure the quality of service (Quality of Service) DAS-3224/E/C supports 8 priority queues IEEE 802.1p and network architecture for DiffServ, which defines a simple mechanism for structured classification and bandwidth management. DiffServ allows for a minimum expectation for service, delay-sensitive - for example, voice or video, while the traffic is not delay-sensitive services, including Web-traffic or file transfers will be sent out depending on the employment of bandwidth. DAS-3224/E/C also supports packet classification based on MAC / IP-addresses and ports TCP / UDP.
DAS-3224/E/C IP DSLAM is carried out in 1,2 U metal case and is designed for desktop installation or rack mounting. The device can be installed in 19 "or 23" rack using a mounting kit.
IP DSLAM DAS-3224/E/C ADSL-equipped with 24 ports and 2 combo ports (10/100/1000 Base-T or mini-GBIC).
Using uplink-ports can be combined into a stack of the device IP DSLAM and aggregation of multiple connections to share a network connection.
With a wide range of functions IP DSLAM, DAS-3224/E/C are cost-effective and efficient solution for the implementation of broadband access next generation.
מאפיינים כללים
Features:
Device Interfaces
+ Connector for RJ-45 cable - RS-232 DB type "mama"
+ Gigabit Ethernet port for external control
Network Uplink-interfaces
+ 2 x Combo Port: 10/100/1000 Base-T or mini-GBIC
ADSL Standards
+ ANSI T1.413
+ ITU-T G.992.1, (G.dmt) Annex A
+ ITU-T G.992.2, (G.lite) Annex A
+ ITU-T G.992.3 (ADSL2)
+ ITU-T G.992.3 Annex L (RE-DSL)
+ ITU-T G.992.5 (ADSL2 +)
+ ITU-T G.992.5 (Annex M)
Throughput
+ Uplink-network interface - network uplink-Interface: 1 Gbit / s per port
+ Uplink-Network Interface - Interface ADSL-access: maksmum 28Mbit / s (Downstream), 2,8 Mbit / s (Upstream with AnnexM)
Subscriber interfaces ADSL
+ 24 ports (1 connector Line RJ-21, 1 POTS RJ-21 connector on the front panel)
Alarm I / O
+ 4 Input Alarm
+ 1 Output Alarm
ADSL-speed transmission of data
+ Upstream: 32 kbit / s to 2800 kbit / s with a step change of 32 kbit / s
+ Downstream: from 64 kbps to 28000 kbps in increments 32 kbit / s
ATM protocol
+ Ethernet over ATM (RFC 1483 bridged)
+ IPoA (RFC 1483 routed)
+ PPPoA (RFC 2364)
+ PPPoE (RFC 2516)
Certificates
+ CE, EN 55022 Class A / CISPR 22, CB Report, IEC60950-1 RoHS Directive
Diagnostic LEDs
+ Alarm, power, DSL-status
System Management
+ Monitoring the status and emergency situations
- Automatic alarm and reports on the reclassification of
+ Performance Monitoring
- Linear speed
- Monitoring bandwidth
- Collect performance metrics for ADSL-line in accordance with RFC 2662 / RFC 3440
- Support for ICMP ping test
+ Setting
- Add, delete, query and change configuration features
- Configuring IGMP snooping
- Configuring VLAN
- Configuring STP / RSTP
- Manage subscriber line ADSL through profile settings
- Upgrading and downloading software via TFTP
- BOOTP / DHCP-Client
+ Security
- Ensuring security and support for two levels of privileges to login
VLAN
+ IEEE 802.1Q VLAN Tagging, VLAN port-based and GVRP
+ Simultaneous support for VLAN 512
+ IEEE 802.1ad VLAN stacking and VLAN translation
Aggregation
+ Static and Dynamic Link Aggregation 802.3ad
Quality of Service (QoS)
+ IEEE 802.1p (8 priority queues)
+ DiffServ
+ Classification of packets based on MAC / IP-address and port number of TCP / UDP
Multicasting
+ Support for IGMP Snooping-based protocols IGMPv1, IGMPv2 and IGMPv3
+ Up to 256 multicast groups and 256 copies of the device
+ Broadcast Storm Control
Bridge Mode
+ 4 K MAC-addresses
+ Filtering MAC / IP-address and TCP / UDP-ports
+ Support agents DHCP / PPPoE intermediate (relay)
+ Option 82, Circuit ID and Remote ID
+ IPOA-to-IPOE internetworking
+ PPPoA-to-PPPoE internetworking
Diagnosis, OAM, and access control
+ Protocol diagnosis DELT
+ Limit the number of MAC addresses ADSL-customer
+ Diagnosis ICMP Ping
+ ATM OAM F5 Diagnostics
Network Management
+ Command-line interface CLI via console or Telnet
+ SNMP v1/v2c
+ Web-management
+ Setting up, troubleshooting, performance, security management
+ Support for NMS
Physical parameters
Nutrition
+ Model that runs on alternating current: 100-240 VAC, 47-63 Hz
+ Model that runs on DC: 85 W, 36-72 V DC 2 A
Dimensions
+ 449.58 x 320 x 49,78 mm
Width
+ 19 inches or 23 inches with mounting kit ( "ears»), 1,2 U
Temperature
+ Operating Temperature: -40 ° ~ 65 ° C
+ Storage Temperature: -40 ° ~ 70 ° C
Humidity
+ 5% to 95% non-condensing
