DSL-2600UEOL EOS
מודם-נתב ADSL אלחוטי עם כניסת רשת אחת
תאור
Affordable solution for high-speed connectivity for home and small office
DSL-2600U/NRU implements all necessary functions for a secure, high-speed wireless and wired networks: support for standards ADSL/ADSL2/ADSL2 +, support for standard Fast Ethernet, built-in firewall mechanism to ensure data quality (QoS), as well as many additional features .
Security
The router provides firewall. Enhanced security features allow you to minimize the effects of hackers and prevent intrusion into your network and access to undesirable Web sites for users on your LAN.
Wireless Interface
You will be able to quickly organize a wireless network at home and office, which will allow your employees or your family member connect to a wireless network almost anywhere (in the range of a wireless network). The router works with standard wireless devices and supports 802.11n * Device 802.11b and g. The device supports several security standards (WEP, WPA/WPA2), filter plug-in device MAC-address, and allows the use of technology to WPS.
Configuring and Managing
To control and configure the router DSL-2600U/NRU used a simple and convenient built-in web-based interface (available in several languages).
* Maximum wireless chipset is limited to 65 Mbit / c.
מאפיינים כללים
Interfaces
• ADSL: 1 port with RJ-11
• LAN: an Ethernet-port 10/100BASE-TX with RJ-45 connector with auto MDI / MDIX cross
• WLAN: built-in wireless interface standard 802.11b/g/n draft
Wireless Network
• Standard IEEE 802.11n draft *, compatible with current standard IEEE 802.11b / g
• Support for guest wireless network
• WEP-encryption
• WPA/WPA2 encryption technology with the mechanisms of TKIP, AES and TKIP + AES
• Access to a wireless network based on the MAC-address
• PIN and PBC methods WPS function
• Advanced Settings
ADSL standards
• ADSL: multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G . hs)
• ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A / L / M, ITU-T G.992.4 (G.lite.bis) Annex A.
• ADSL2 +: ITU-T G.992.5 Annex A / L / M
Types of WAN-connection
• ADSL:
  - PPPoA
  - PPPoE
  - IPoE
  - IPoA
  - Bridge
• Ethernet:
  - IPoE
  - PPPoE
  - Bridge
Operating frequency
2.4 ~ 2.484 GHz ISM band in
Data transfer rate
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit / c
• IEEE 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• IEEE 802.11n draft: 20 MHz bandwidth, up to 65 Mbit / s
Transmitter output power
• IEEE 802.11b: 16,5 ~ 18,5 dBm
• IEEE 802.11g: 13,5 ~ 16,5 dBm
• IEEE 802.11n draft: 13,5 ~ 16,5 dBm
ATM / PPP
• Encapsulation of Ethernet in bridge and router
• Multiplexing-based VC / LLC
• ATM Forum UNI3.1/4.0 PVC (up to 8 PVC)
• ATM Adaptation Layer Type 5 (AAL5)
• The principles and functions of OAM ITU-T I.610, including F4/F5 loopback
• ATM QoS
• PPP over ATM (RFC 2,364)
• PPP over Ethernet (PPPoE)
• Support for Keep-alive for PPP-protocol
Network Protocols and Features
• Static IP-routing
• The mechanism of NAT
• DHCP-server/klient/relay
• DNS relay
• Dynamic DNS (DDNS)
• UPnP
• VLAN support
• IGMP proxy
Firewall and Access Control
• NAT firewall
• Monitor status of network connections (SPI)
• Filtering by MAC-addresses from the time of day and day of the week
• URL-filter
• Packet filtering (IP / ICMP / TCP / UDP)
• Virtual Servers
• Prevent DoS-attacks
• Intrusion detection and logging
• Technology to protect DMZ
• Supports Port Triggering
QoS
• Grouping interfaces
• 3 priority queues
• Web-based configuration and management in multiple languages
• Access to TELNET
• Update the router's internal software via web-interface
• Save and load configuration
• Support for remote logging
• SNMP-agent
• Automatic synchronization of system time from NTP-server
תקנים
הורדות
איורים
DSL-2600U/C4
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
