חיפוש מהיר
תכונות המוצר:
מודם-נתב +ADSL/ADSL2/ADSL2 אלחוטי בתקן 802.11N בעל 4 יציאת רשת ועם תמיכה ב-QOS
דגם לא מיוצר יותר
תאור:
DSL-2740U/NRU - is an affordable high performance ADSL/Ethernet-router for a small office and home networks. It allows you to quickly and easily get access to broadband Internet technology as ADSL, and Ethernet, and organize the sharing of a communication channel among multiple users.
DSL-2740U/NRU implements all necessary functions for a secure, high-speed wireless and wired networks: support for standards ADSL/ADSL2/ADSL2 +, support for Fast Ethernet standard , built-in firewall mechanism to ensure data quality (QoS), as well as many additional features .
The router is equipped with ADSL-port for connecting to the ADSL-line and 4 Ethernet-ports for connecting workstations. With this DSL-2740U/NRU is an economical solution to create a wired network and eliminates the need to install a separate switch. In addition, any Ethernet-port devices can be used to connect to a dedicated Ethernet-line.
DSL-2740U/NRU can serve as a base station to connect to a wireless network devices that run on standard 802.11b, 802.11g and 802.11n *. The Router provides many functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filter plug-in device MAC-address, and allows the use of technology to WPS. Wireless Router DSL-2740U/NRU provides firewall. Enhanced security features allow you to minimize the effects of hackers and prevent intrusion into your network and access to undesirable Web sites for users on your LAN. To manage and configure DSL-2740U/NRU used a simple and convenient built-in web-based interface.
* Maximum wireless speed is limited to 135 Mbps.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
