חיפוש מהיר
תכונות המוצר:
נתב אלחוטי דואל-בנד בתקן AC1200 עם 4 יציאות ג'יגהביט, יציאת WAN אופטית, כניסת USB ותמיכה ב - 3G/CDMA/LTE
מאפיינים כללים:
Interfaces
• 1000BASE-X SFP WAN port
• 4 10/100/1000BASE-T LAN ports
• USB 2.0 port
LEDs
• POWER
• 2.4GHz
• 5GHz
• SFP
• 4 LAN LEDs
• USB
• WPS
Buttons
• ON/OFF button to power on/power off
• RESET button to restore factory default settings
• WPS button to set up secure wireless connection and enable/disable wireless network
Antenna
• Two external non-detachable antennas (2.5dBi gain)
MIMO
• 2 x 2
Power connector
• Power input connector (DC)
WAN connection types
• LTE
• 3G
• PPPoE
• Static IP / Dynamic IP
• PPPoE + Static IP
• PPPoE + Dynamic IP
Network functions
• DHCP server/relay
• DNS relay
• Dynamic DNS
• IGMP Proxy
• RIP
• Support of UPnP IGD
• Support of VLAN
• WAN ping respond
• Support of SIP
• Support of RTSP
Firewall functions
• IP filters
• MAC filter
• URL filter
• Prevention of ARP and DDoS attacks
• Virtual servers
VPN
• IPSec/PPTP/L2TP/PPPoE pass-through
USB interface functions
• USB modem
   Auto connection to available type of supported network (4G/3G/2G)2
   Enabling/disabling PIN code check, changing PIN code3
• USB storage
   File browser
   Print server
   Access to storage via accounts
   Built-in Samba server
   Built-in FTP server
   Built-in DLNA server
   Built-in Transmission torrent client; uploading/downloading files from/to USB storage
Management
• Local and remote access to settings through TELNET/WEB (HTTP)
• Multilingual web-based interface for configuration and management
• Support of remote logging
• Ping function
• Traceroute utility
• TR-069 client
Wireless Module Parameters
Standards
• IEEE 802.11a/n/ac
• IEEE 802.11b/g/n
Frequency range
• 2400 ~ 2483.5MHz
• 5150 ~ 5350MHz
Wireless connection security
• WEP
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• WMM (Wi-Fi QoS)
• Managing connected stations
• Advanced settings
Wireless connection rate
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n (2.4GHz/5GHz): from 6.5 to 300Mbps (from MCS0 to MCS15)
• IEEE 802.11ac (5GHz): from 6.5 to 867Mbps (from MCS0 to MSC9)
Transmitter output power
• 802.11a (typical at room temperature 25 °C)
17dBm at 6, 9, 12, 18, 24, 36, 48, 54Mbps
• 802.11b (typical at room temperature 25 °C)
14dBm at 1, 2, 5.5, 11Mbps
• 802.11g (typical at room temperature 25 °C)
14dBm at 6, 9, 12, 18, 24, 36, 48, 54Mbps
• 802.11n (typical at room temperature 25 °C)
2.4GHz, HT20
13dBm at MCS0~15
2.4GHz, HT40
12dBm at MCS0~15
5GHz, HT20/HT40
17dBm at MCS0/8
15dBm at MCS7/15
• 802.11ac (typical at room temperature 25 °C)
VHT20/VHT40/VHT80
17dBm at MCS0
15dBm at MCS9
Receiver sensitivity
• 802.11a (typical at PER < 10% at room temperature 25 °C)
-87dBm at 6Mbps
-86dBm at 9Mbps
-84dBm at 12Mbps
-82dBm at 18Mbps
-79dBm at 24Mbps
-76dBm at 36Mbps
-71dBm at 48Mbps
-70dBm at 54Mbps
• 802.11b (typical at PER = 10% at room temperature 25 °C)
-84dBm at 1, 2Mbps
-82dBm at 5.5Mbps
-79dBm at 11Mbps
• 802.11g (typical at PER = 10% at room temperature 25 °C)
-82dBm at 6Mbps
-81dBm at 9Mbps
-79dBm at 12Mbps
-77dBm at 18Mbps
-74dBm at 24Mbps
-70dBm at 36Mbps
-66dBm at 48Mbps
-65dBm at 54Mbps
• 802.11n (typical at PER < 10% at room temperature 25 °C)
2.4GHz, HT20
-82dBm at MCS0/8
-79dBm at MCS1/9
-77dBm at MCS2/10
-74dBm at MCS3/11
-70dBm at MCS4/12
-66dBm at MCS5/13
-65dBm at MCS6/14
-64dBm at MCS7/15
2.4GHz, HT40
-79dBm at MCS0/8
-76dBm at MCS1/9
-74dBm at MCS2/10
-71dBm at MCS3/11
-67dBm at MCS4/12
-63dBm at MCS5/13
-62dBm at MCS6/14
-61dBm at MCS7/15
5GHz, HT20
-86dBm at MCS0/8
-83dBm at MCS1/9
-81dBm at MCS2/10
-77dBm at MCS3/11
-75dBm at MCS4/12
-70dBm at MCS5/13
-69dBm at MCS6/14
-68dBm at MCS7/15
5GHz, HT40
-83dBm at MCS0/8
-80dBm at MCS1/9
-78dBm at MCS2/10
-75dBm at MCS3/11
-72dBm at MCS4/12
-67dBm at MCS5/13
-66dBm at MCS6/14
-65dBm at MCS7/15
• 802.11ac (typical at PER < 10% at room temperature 25 °C)
VHT20
-61dBm at MCS8
-59dBm at MCS9
VHT40
-58dBm at MCS8
-56dBm at MCS9
VHT80
-80dBm at MCS0
-77dBm at MCS1
-75dBm at MCS2
-71dBm at MCS3
-69dBm at MCS4
-64dBm at MCS5
-62dBm at MCS6
-61dBm at MCS7
-56dBm at MCS8
-53dBm at MCS9
Modulation schemes
• 802.11a: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11b: DQPSK, DBPSK, CCK
• 802.11g: BPSK, QPSK, 16QAM, 64QAM, OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11ac: BPSK, QPSK, 16QAM, 64QAM, up to 256QAM with OFDM
נתונים פיזיים
Dimensions
• 227 x 159 x 38 mm (8.93 x 6.26 x 1.5 in)
Weight
• 160 g (0.35 lb)
Power
• Output: 12V DC, 1.5A
Temperature
• Operating: from 0 to 40 °C
• Storage: from -20 to 65 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 5% to 95% (non-condensing)
Supported USB modems 4
GSM
• Alcatel X500
• D-Link DWM-152C1
• D-Link DWM-156A6
• D-Link DWM-156A7
• D-Link DWM-156C1
• D-Link DWM-157B1
• D-Link DWM-157B1 (Velcom)
• D-Link DWM-158D1
• Huawei E150
• Huawei E1550
• Huawei E156G
• Huawei E160G
• Huawei E169G
• Huawei E171
• Huawei E173 (Megafon)
• Huawei E220
• Huawei E352 (Megafon)
• Huawei E367 (3G mode)
• Huawei E392 (3G mode)
• ZTE MF112
• ZTE MF192
• ZTE MF626
• ZTE MF627
• ZTE MF652
• ZTE MF667
• ZTE MF668
• ZTE MF752
CDMA
• Airplus MCD-650
• Airplus MCD-800
• AnyDATA ADU-300A
• AnyDATA ADU-500A
• AnyDATA ADU-510A
• Huawei EC306
• ZTE AC5710
• ZTE AC5730
LTE
• Huawei E3131
• Huawei E3272
• Huawei E3351
• Huawei E367
• Huawei E392
• Megafon M100-1
• Megafon M100-3
• Megafon M100-4
• Megafon M150-1
• MTS 824F
• Yota LU-150
• Yota WLTUBA-107
• ZTE MF823
• ZTE MF827
1 Up to 300Mbps for 2.4GHz and up to 867Mbps for 5GHz.
2 For LTE and GSM USB modems.
3 For GSM USB modems only.
4 The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
