חיפוש מהיר
דגם ישן
תכונות המוצר:
פיירוול UTM (כולל AV, WCF) לאבטחה מושלמת לרשת הארגונית - 4 יציאות LAN, יציאת WAN, יציאת DMZ - עד 80Mbps
מאפיינים כללים
מאפיינים כללים:
Technical Specifications
Firewall Mode of Operation
Layer 3 Mode: Route Mode, NAT Mode
Layer 2 Mode: Transparent Mode
Network Address Translation (NAT)
Port Address Translation (PAT)
Policy-Based NAT
Port Forwarding
Static Address Translation (SAT)
Time Scheduled Policies
VPN Security
VPN Tunnels: 100* (IPSec, PPTP, L2TP)
IPSec LAN-to-LAN / Roaming User
PPTP/L2TP Server/Client
IPSec/PPTP/L2TP Pass-through
IPSec NAT-Traversal
DHCP over IPSec
Encryption Transform: DES, 3DES, AES, Twofish, Blowfish, CAST-128
XAUTH (Extended Authentication) for IPSec Authentication
Firewall Security
Stateful Packet Inspection (SPI)
Policy-Based User Authentication
DoS/DDoS Attack Protection
RADIUS, LDAP, IAS
HTTP Traffic Filter: Keyword, URL, Exempt List
Script Filter: Java Applet, Java Scripts, VB Scripts, Cookies, ActiveX
Network Service
Static IP address
PPPoE for xDSL
PPTP/L2TP Client for xDSL
DHCP Client for WAN Interface
BigPond Cable, Telia Compliance
Internal DHCP Server
DHCP Relay
WAN Failover/Load Sharing**
IP Alias
Static Routes
Policy-Based Routing
DNS Resolving of Remote Gateway
Dynamic DNS Poster
Custom Application Layer Gateway
Support IEEE 802.1q VLAN Tag (8)
Firewall Policies per VLAN Tag
DHCP Server per VLAN Tag
Bandwidth Management
Guaranteed Bandwidth
Maximum Bandwidth
Priority-Bandwidth Utilization
Policy-Based Traffic Shaping
Time-Scheduled Traffic Shaping
Bandwidth Management in VPN Tunnel
System
SYSLog Support
Firmware Configuration Backup
E-mail Alerts
Management – HTTP/HTTPS/SSH
Simple Network Time Protocol (SNTP)
Simple Network Management Protocol (SNMP)
Configuration Consistency Checks
Intrusion Detection System
NIDS Pattern Auto Update
Attack Alarm via E-mail Notification
Device Ports
WAN: 1 10/100BASE-TX Port
LAN: 4 10/100BASE-TX Ports
DMZ/WAN2: 1 10/100BASE-TX Port
Console Port: Serial COM Port
Diagnostic LED
Power
System
LAN (Link/Activity per Port)
WAN (Link/Activity per Port)
DMZ (Link/Activity per Port)
Power Input
5VDC, 3.0A Switching External Power Supply
Power Consumption
15 Watts max.
Dimensions
Item: 9.25” x 6.38” x 1.42”
Packaging: 10.79” x 8.19” x 4.64”
Weight
Item: 1.1 lbs
Packaging: 2.66 lbs
Temperature
Operating: 32°F to 140°F
Storage: -4°F to 158°F
Humidity
5% to 95% (Non-Condensing)
Emission (EMI)
FCC Class A
CE
C-Tick
Safety
UL
TUV
LVD (EN60950)
Warranty
3 Year Limited
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה
