חיפוש מהיר
תכונות המוצר:
מתאם רשת אלחוטי למחשב נייח מסדרת Rangebooster N לתקן 802.11n
תאור:
ULTIMATE PERFORMANCE
The D-Link Xtreme N™ Desktop Adapter (DWA-547) is a draft 802.11n wireless client that delivers unrivaled wireless performance for your desktop computer. This wireless adapter delivers up to 14x faster speeds* and 6x farther range* than 802.11g while staying backward compatible with 802.11g networks. Once connected, you can share a high-speed Internet connection, photos, files, music, videos, printers, and storage.
GET CONNECTED, STAY CONNECTED
The Xtreme N Desktop Adapter is powered by Xtreme N technology and boasts three external antennas to provide superior wireless reception in your home or office. This adapter is designed for use in larger homes and offices, or for users running multiple bandwidth-intensive applications. This adapter enables you to simultaneously make or receive Internet phone calls (VoIP), surf the Web, transfer files, and stream High-Definition (HD) media when connected to an Xtreme N Gigabit Router (DIR-655 or DIR-660)*. The DWA-547 supports WPA™ and WPA2™ encryption that allow you to connect securely to a wireless network.
EASY TO SETUP, EASY TO USE
D-Link’s Quick Adapter Setup Wizard guides you step-by-step through the installation process. Configure this desktop adapter without having to call a networking expert to help you. With unmatched wireless performance, reception, and security, the D-Link Xtreme N Desktop Adapter (DWA-547) is the best choice for easily adding or upgrading wireless connectivity to your desktop computer.
WHAT THIS PRODUCT DOES
Connects your desktop computer to a wireless network and access a high-speed Internet connection, transfer files, and stream media from greater distances around your entire home or office.
XTREME N™ ADAPTER BENEFITS
Delivers up to 14x faster speeds and 6x farther range than 802.11g.
Xtreme N technology enables HD video sreaming, file sharing, enhanced Internet phone calling (VoIP), and surfing the Web.
Access a secure wireless network using advanced WPA™ or WPA2™ encryption.
Easy to install and use with D-Link’s new Quick Adapter Setup Wizard.
Backward compatible with existing 802.11g networks.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה
