DVA-N6670BEOL EOS
תאור
Everything you need for a home
Get everything from the D-Link DVA-N6670B Wireless N VoIP VDSL2 Modem Router. This all encompassing device includes an integrated high-speed VDSL2 modem, two VoIP phone connections, 802.11n wireless interface, and a 4-port Ethernet switch. This router provides all the functions that your home needs to establish a fast, secure Internet connection, make and receive Internet calls, and wirelessly share the Internet link with your family members.
Fast VDSL speed for clear Internet phone
The DVA-N6670B provides VDSL speeds of up to 100 Mbps downstream and 50 Mbps upstream, suitable for Internet phone calls. It combines the industry’s latest Voice over IP technology with advanced communication features, and is compatible with industry-wise phone services. With two FXS phone ports and a FXO lifeline, this router can connect to two ordinary phone sets for two simultaneous phone calls, and relay phone calls to PSTN automatically in case of a
power outage, so your phone line will always be available.
Secure wired and wireless connection
The DVA-N6670B provides an integrated 802.11n WLAN supporting wireless speeds of up to 300 Mbps, and four Ethernet ports to connect to four computers through the network cables. It provides WEP data encryption and WPA/WPA2 wireless security, Stateful Packet Inspection (SPI) firewall protection, MAC/IP/Port access filtering access, and day/time parental control. Traffic prioritization and classification enable your home to experience smooth VoIP and streaming media without concern of traffic congestion.
מאפיינים כללים
Device Interfaces
• 2 FXS ports with RJ-11 connectors
• 1-Port FXO (lifeline) with RJ-11
• 4-port LAN 10/100BASE-TX Ethernet c RJ-45 connectors and auto-sensing MDI / MDIX (computers)
• 1 USB 2.0
• 802.11n WLAN (wireless access point for connecting computers)
• Reset button to return to default settings
• Power switch ON / OFF
• Switch wireless ON / OFF
• WPS Button
Options VDSL
• VDSL Transmission Band Plan: ITU-T G.993.2
• Duplex VDSL: Frequency Division Duplexing, FDD for two DS / US
• How to channel coding VDSL: Multi-Carrier Modulation (MCM)
• 5-frequency operation in ITU-T G.993.2, including U0, DS1, US1, DS2, US2, range from 25 kHz to 17 MHz
• VDSL Handshake Procedure: compliance with ITU-T G.994.1
• VDSL Physical-layer supports "Packet Transport Mode (PTM)"
• Support for adaptation rate
• Support for a status line VDSL
• Capacity: Downstream - 100 Mbit / s, outgoing - 50 Mbit / s.
Support for VOIP
• SIP (RFC 3261)
Support for the phone functions
• Supports binary DTMF dialing
• Support for Caller ID
Audio codecs
• G.711u-law/A-law
• G.723.1
• G.726
• G.729A / B
Echo
• G.168
Supports fax function
• Transparent fax (G.711)
• VoIP NAT Traversal
• SIP
Functions of WLAN
• Standard 802.11b / g
• The 802.11n standard
• Speed WLAN: up to 54 Mbit / s (802.11g), up to 300 Mbit / s (802.11n)
• Frequency range: 2.4 GHz to 2.484 GHz
• Antennas: Dual embedded antenna MIMO 2x2
• 64/128-bit WEP-encryption
• WPA/WPA2 (Wi-Fi Protected Access) security
• Multiple SSID
• 802.11e Wireless QoS (WMM / WME)
• Access Control MAC-based
Transfer rate
DSL:
• Upstream: up to 100 Mbit / s
• Downstream: up to 50 Mbit / s
WLAN:
• 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11b: 11, 5.5, 2 and 1 Mbit / s
• 802.11n:
- 20 MHz BW: 130, 117, 104, 78, 52, 39, 26, 13 Mbit / s
- 40 MHz BW: 270, 243, 216, 162, 108, 81, 54, 27 Mbit / s
Frequency band
• 2400 ~ 2484.5 MHz
Transmitter power
• 802.11g: 14.0 ~ 15.0 dBm
• 802.11b: 16.0 ~ 18.0 dBm
• 802.11n 2x2: 13.5 ~ 16.5 dBm
Network Protocols and Features
• NAT / NAPT (RFC 1631)
• RIP v1 (RFC 1058)
• RIP v2 (RFC 1389)
• Static Routing
• DNS
• TCP / UDP
• ARP / RARP (RFC 826)
• ICMP (RFC 791)
• DHCP server / client (RFC 2131)
• IP Multicast - IGMP Proxy / Snooping
• UPnP compatible
• Virtual Server / Port Forwarding
• DMZ
• SNTP / NTP
• Share this printer
Firewall / Secure Access
• Built-in NAT firewall
• Prevention of DoS-attacks
• Packet filtering based on port, source IP-addresses, MAC-address (ICMP / TCP / UDP)
Virtual Private Network (VPN)
• PPTP/L2TP/IP Sec pass-through
QoS
• VLAN port mapping QoS for four ports, 4 LAN
• Classification of packets (IP / MAC / port and physical port)
• IP ToS
Configuration / Management
• Quick Installation Wizard
• Web-interface for remote / local control
• Update, setting the update / download via Web-interface
• Telnet-Server for remote / local control
• Event Monitoring using log Syslog
• Supports SNMP v.1, v.2c with built-in database MIB-I & MIB-II (RFC 1213)
• TR-069
Bandwidth Management
• IGMP Snooping
• VLAN port mapping
Diagnostic Lights
• Power
• LAN 1 - 4
• WLAN
• USB
• PSTN
• VDSL
• Internet
• WPS
