חיפוש מהיר
תכונות המוצר:
מודול הרחבה ל DPH-400S/E/F3 ו DPH-400SE/E/F3
תאור:
External extension DPH-400EDM designed to connect to IP-telephones DPH-400S/SE. Each module has 26 physical keys. Each button module can be programmed for a specific function, such as voice mail, call forwarding function "do not disturb", etc. Also, you can assign them to a choice of lines, when you press the button is engaged in one of the SIP lines. Power supply of the DPH-400EDM can be done directly with the IP-phones (up to 2 modules), to which they are connected.
The use of expansion modules DPH-400EDM allows for IP-Phones for small businesses, call centers, where the need to control and manage large numbers of calls.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
