DPH-400EDM/E/F3
מודול הרחבה ל DPH-400S/E/F3 ו DPH-400SE/E/F3
תאור
External extension DPH-400EDM designed to connect to IP-telephones DPH-400S/SE. Each module has 26 physical keys. Each button module can be programmed for a specific function, such as voice mail, call forwarding function "do not disturb", etc. Also, you can assign them to a choice of lines, when you press the button is engaged in one of the SIP lines. Power supply of the DPH-400EDM can be done directly with the IP-phones (up to 2 modules), to which they are connected.
The use of expansion modules DPH-400EDM allows for IP-Phones for small businesses, call centers, where the need to control and manage large numbers of calls.
מאפיינים כללים
Interfaces
• 1 IN port 10/100Base-T with RJ-11 connector for connection to the VoIP phone
• 1 Out port 10/100Base-T with RJ-11 connector for an optional expansion module (DPH-400EDM)
• 1 x 5V DC to connect to the power adapter
Keys
• 26 DSS keys with dual color LED
Phone functions
• DTFM
• BLF List Key
• Speed ​​dialing
• MWI
• Appointment of SIP-DSS-line keys
• Remote phone book
• Up to five expansion modules (130 DSS keys)
Key functions
• Inclusion of a call
• Disable call-
• Callback
• Call forwarding
• "Do not disturb» (DND)
• Flash
• Headphones
• Call History
• Joint use of the phone (Hot Desking)
• Call Hold (Hold)
• Join call
• Lock
• Memo
• MWI
• Phonebook
• Call Pickup (Pickup)
• Prefix
• Redial (Redial)
• Release
Network control
• HTTP for remote software upgrade
תקנים
הורדות
איורים
DPH-400EDM/E/F3/F3
מראה מקדימה
מראה מימין
מראה מימין
מראה מימין
דף מידע
ראה גם
