חיפוש מהיר
תכונות המוצר:
VOIP Gateway עם 8 יציאות FXS, יציאת WAN, כ- 4 יציאות LAN וראוטר מובנה
תאור:
DVG-5008SG converts voice traffic into data packets for transmission over the Internet. The Gateway combines the latest Voice over IP technology with advanced communication features, and is fully compatible with Internet-phone SIP. Gateways with high density and low cost, provide convenience and guaranteed savings for companies needing to place frequent long-distance and international business calls.
Saving and a profitable investment
VoIP-Gateway DVG-5008SG with FXS-port provides an easy and inexpensive upgrade Internet telephony, allowing users to store previously purchased phones and fax machines. Investment protection is achieved through the use of existing infrastructure and the possibility of its gradual modernization.
Guaranteed quality of voice
Gateway DVG-5008SG transmits voice and fax messages in accordance with internationally recognized standards for voice and data, such as G.722, G.711, etc. Support for Quality of Service (QoS) ensures call quality comparable to analog phone.
Call Functions
VoIP-Gateway DVG-5008SG with FXS-port supports multiple calling features that allow service providers to provide their customers with services such as call waiting, "Do Not Disturb", speed dialing, three-way conference, etc. Besides, there are many management functions SIP, including Proxy server support for outgoing calls, duplicate registration for SIP proxy servers / failover registration SIP, function dial plan (dial plan) and the group call function. Customize the phone connection by running the multi interactive voice (IVR) or the Web-interface.
Multiple simultaneous connections
VoIP-Gateway DVG-5008S is equipped with eight FXS-ports, providing multiple simultaneous connections. For the organization of Internet phone just connect to these ports regular phones. These gateways are the ideal solution for companies to make phone calls to long-distance and international destinations.
Gigabit ports to provide broadband Internet access
Gateway provides easy routing function, which allows users to get a joint office broadband Internet access. You can connect your computer to this gateway with built-in 4-port Ethernet and use the built-in NAT / DHCP-server to automatically access the Internet.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
