חיפוש מהיר
תכונות המוצר:
טלפון VOIP עם תמיכה ב SIP ו PoE
תאור:
Making calls over the Internet for home and office
IP-phone DPH-150SE/F3 allows connection to the DSL / cable modem connection to make inexpensive Internet phone calls. This device combines the advantages of modern Voice over IP technology with advanced communication features. Telephone DPH-150SE/F3 to take advantage of VoIP technology with quality comparable to conventional telephones.
High quality voice
IP-phone DPH-150SE/F3 supports QoS, thus ensuring the quality of transmission and reception of voice, similar to using a conventional telephone. In addition, this phone supports many useful functions such as call transfer, caller ID, three-way conference and function of the "speed dial". Make it convenient to dial out or answer phone calls.
Simultaneous viewing pages in the Internet and make phone calls
DPH-150SE/F3 Phone with 2-port Ethernet, one of which is intended for connection to a cable / DSL-modem or broadband router. The second Ethernet port allows you to connect a personal computer. In this case, it will be possible to simultaneously talk on IP-phone, browse Web-sites, send e-mail, transfer files, and perform other tasks on the computer network.
Integrated Safety
DPH-150SE/F3 support the option of Voice VLAN, which allows you to isolate and secure voice traffic transmitted over the Internet. It also supports traffic prioritization, allowing the transfer of files and work with Web-sites without compromising voice quality for Internet telephony.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
