חיפוש מהיר
תכונות המוצר:
VOIP Gateway עם 32 יציאות FXO, יציאת WAN, יציאת LAN
מאפיינים כללים:
Device Interfaces
• 32 ports FXO c 2 x RJ-21
• Port 10/100BASE-TX RJ-45 WAN
• Port 10/100BASE-TX RJ-45 LAN
Types of connections
• DHCP-client
• PPPoE-client
• PPTP
• Cable BigPond (Australia)
Phone book
·Server phone book management, up to 200 entries IAD
SIP
• Register port "By Port" "By machine
• Dialing in the standard E.164
• Redundant SIP PROXY (registration)
• SIP PING
• CLIR (Anonymous Caller ID)
• Function hot line / warm line
• Functions of a group call
• Hold, Call Waiting, Call
• Call forwarding: with accompaniment / unaccompanied
• Call forwarding: unconditional, busy, no answer
• 3-way conference
• T.30 fax pass-through
• T.38 fax relay
• Adjustable tone detection Fax
• Out of band DTMF: RFC2833, SIP INFO
Voice Features
• G.711 a / u, G.726 (32K), G.729A, G.723.1
• Adjustable jitter-buffer
• Variable packet size (depending on codec)
• Detection and Noise Reduction
• Echo
• Local phone book enables you to call other VoIP devices without registration
• Speed ​​Dial
• Call filter - accept / reject calls from the IP-address
• ID-generation FXS-Call: DTMF, FSK (Bell core / ETSI)
• Support the FLASH button
Management
• Web-based interface and Telnet, IVR
Indicators
• Power
• Reset
• Alarm
• Run
• From 1 to 32
נתונים פיזיים
Input voltage
• 90-260 VAC, 50/60 Hz
• Internal power supply
Dimensions
• 442 x 330 x 43 mm
• Installation in 19 "rack, 1U
Weight
• 4.4 kg
Operating temperature
• From 0 to 45 C
Storage temperature
• -25 To 75 C
Humidity
• Up to 95% noncondensing
Radiation (EMI)
• FCC Class A
• CE
Security certificate
• UL
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
