חיפוש מהיר
דגם ישן
תכונות המוצר:
ממיר VoIP לטלפונים אנלוגיים.2 יציאות FXS ל- 2 טלפונים, יציאת WAN לאינטרנט ויציאת FXO לשקע אנלוגי כגיבוי
מאפיינים כללים
מאפיינים כללים:
Specifications:
Interface Device
·         2 FXS phone ports with RJ-11 connectors, with the detection and generation change polarity
·         1 PSTN lifeline phone port with RJ-11 connector
·         1-port WAN 10/100BASE-TX with RJ-45 jack and auto-polarity of MDI / MDIX
·         1-port LAN 10/100BASE-TX with RJ-45 jack and auto-polarity of MDI / MDIX
Type of access WAN
·         PPPoE
·         Static IP-address
·         DHCP-Client
·         Customer PPTP/L2TP
·         Cable BigPond (Australia)
·         MAC-cloning on WAN port
Router
·         DHCP-server
·         Virtual server
·         DMZ
·         Static routing
·         DDNS: DnsDyn.org, Easy DNS, IP
·         NAT Traversal STUN client, UPnP, Outbound Proxy
·         NAT / PAT (RFC1631/RFC3235)
·         Support for the bridge mode
·         Safe access to the router
·         Port Filtering
·         Filtering of IP-addresses
·         MAC-address filtering
Parental Control
·         Filtering URL-address
·         Scheduling
VPN
·         PPTP/L2TP/IPSec pass-through
QoS
·         Class of Service (COS) based on:
·         Queue priorities 802.1p (8 queues)
·         The prevalence of IP-addresses
·         DiffServ
VLAN
·         802.1Q Tagging
·         Voice VLAN
VoIP
·         SIP ALG Through, NetMeeting ALG
·         SIP and the organization of the queue by priority RTP
·         RTP Packet Summary sent, received, loss packet count
Management
·         Web-Based Interface
·         Telnet
·         Administration on the basis of multilevel password
·         Remote software update via HTTP, TFTP, FTP,
·         Built tools PING
·         Multifunctional restoration: a return to factory settings
·         TR-069 (includes a TR-104) (optional)
·         NTP: 3 servers support time, time zones
·         Reset Button
Voice
·         Conformity SIP v2 (RFC3261)
·         SIP METHOD ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, PING,
·         PRACK, REFER, REGISTER, SUBSCRIBE, UPDATE
·         SIP Extension Session Timer, Proxy-Require, P-Asserted (RFC3325), MWI (RFC3842)
·         Voice Compression: G.711 a / u-law, G.726, G.729A/AB, iLBC, G.723.1 (optional)
·         CNG and VAD
·         Detection / suppression pauses
·         G.168 Echo Suppression
·         Adjustable jitter-buffer
·         Software gain control
·         In-band (In-band) DTMF
·         Out-of-band (Out-of-band) DTMF relay (RFC2833)
·         Support DTMF / pulse dialing
·         Resistance lines: integrated resistance 600/900 ohms
·         Restoration of registration for SIP Proxy-server
·         Fault-tolerant mechanism
·         Automatic switching from FXS Relay to PSTN when the following events:
·         Failure of the Internet
·         Inaccessible Service
·         Turn off power
Fax
·         T.30 FAX pass through
·         T.38 real time FAX relay
The functions of the phone
·         Hold call, call waiting, to intercept incoming calls
·         Call forwarding: Certainly, if busy, no answer
·         Call Forwarding: automatic, controlled by an operator
·         Speed dialing, redial at amusing room, 3-sided conference
·         Caller ID: DTMF, FSK-Bell core, detection and generation of FSK-ETSI, Japan CLIP / JCLIP, BT
·         Key «Grid»
·         Support searches numbers
       Phonebook
 ·         E.164 numbering
 ·         Hot line
Indicators diagnosis
·         Power
·         Provision
·         WAN
·         LAN
·         Phone 1 (port FXS)
·         Telephone 2 (port FXS) Dimensions
 90 x 82 x 31 mm
Weight
·         152 g
Power consumption
·         12 VDC, 1.2 A
Power Source
·         Through an external power adapter from 100 to 240 VAC, 50/60 Hz, 0.7A
Operating temperature
·         From -10 ˚ to 40 ˚ C
Storage temperature
·         From -20 ˚ to 60 ˚ C
Working humidity
·         From 10% to 90% non-condensing
Humidity Storage
·         From 5% to 95% non-condensing
Electromagnetic compatibility, certificates
·         FCC Class B
·         CE
Certificates Telecom
·         FCC PART 68
·         CE TBR21
·         A-Tick
Security Certificates
·         (CE) LVD
      Warranty
·         2 years
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה
