תכונות המוצר:
ממיר VoIP לטלפונים אנלוגיים. יציאת FXS ויציאה ל- WAN |
מאפיינים כללים:
Specifications: · 1 FXS port with RJ-11 jack and change the definition
· of polarity (optional) · 1-port WAN 10/100Base-TX with RJ-45 jack and
· automatic polarity of MDI / MDIX · Types of WAN-connection · PPPoE · Static IP-address · DHCP-Client · PPTP/L2TP-klient · Cloned MAC-address on the WAN-port · Quality of Service (QoS) · Class of service (CoS) on the basis of: · IP-priority · 802.1Q Tagging · Voice VLAN (optional)
VoIP · SIP ALG Through · Queue priorities SIP and RTP · Statistics on RTP-packets: The number of sent,
· received and lost packets
Management · Web-management interface
· User interface TELNET · Multi-system password-controlled administration · Update software via TFTP / FTP / HTTP · PING tool · Several options reset settings: reset, restore default · Customer Support TR069/TR104 (optional) · NTP: support for 3-time servers, time zones · Button reset the settings (Reset)
Voice functions · Support for SIP v2 (RFC3261) · Methods SIP: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY,
· OPTIONS, PING, PRACK, REFER, REGISTER, SUBSCRIBE, UPDATE · Enhanced SIP: Session Timer, Proxy-Require, P-
· Asserted (RFC3325), MWI (RFC3842) · Codecs: G.711a/u-law, G.726, G.729A/B/AB, iLBC/G.723.1 (optional) · Comfort Noise Generation (CNG) · Voice Activity Detection (VAD) · Detection / suppression pauses · Adjustable jitter-buffer · Programmable gain control · In-band DTMF · Out-of-band DTMF relay (RFC2833) · Support DTMF / pulse dialing (optional) · Termination impedance (matched load): Setup (optional) · Reserve SIP Proxy-server (registration)
Fax · T.30 fax pass through G.711 · T.38 real time FAX relay · Call Options · Hold call, call waiting, call interception · Call Forwarding (busy, no answer, unconditional) · Transfer call (accompanied, unaccompanied) · Quick set, repeating a call at employment, 3-hstoronnyaya conference. · Caller ID: DTMF, FSK-Bell Core, detection and generation of FSK-ETSI, Japan CLIP / JCLIP, BT · Prefix dialing · Support hunting number · Phonebook · Dialing E.164 · Hot Line
Indicators · Power
· Provision · WAN · Register · Phone (port FXS) · 90 x 82 x 31 mm · Vec · 110g · Dining · At the entrance: via an external power adapter 100-240V, 50-60 Hz AC · The output: 12V DC 1.5 A
Operating temperature · From 0o to 40oC
· Storage temperature · De-20o to 60o? C · Working humidity · From 10% to 90% without condensation
Humidity Storage · From 5% to 95% without condensation
Certificates
· FCC Part 68 · CE TBR21 · Electromagnetic Compatibility · FCC Class B · CE
Security Certificates · (CE) LVD
Warranty
· 2 years
נתונים פיזיים |
ראה גם
