DPR-1040EOL EOS
שרת הדפסה אלחוטי בתקן G עם כניסת USB
תאור
SHARE YOUR PRINTER AND MULTIFUNCTION EQUIPMENT WIRELESSLY
The DPR-1040 Wireless G Print Server lets users share a USB printer across a network, while also providing scan and fax functions to those who use multifunction equipment. Use the WPS button neatly located on the side of the device to set up a secure wireless connection to your router or access point in seconds, giving you the time to enjoy the benefi ts of this stylish and compact device.
HIGH SPEED OPERATION
Equipped with a powerful CPU, large memory, high speed USB 2.0 port and up to 100Mbps network data transfer, this print server makes your operations fast and effi cient. Printers attached to the DPR-1040 can print, scan, and fax at the same time, giving this device better performance than any software-based print server at a fraction of the cost.
ACCESS SECURITY AND MULTIPLE OS SUPPORT
The DPR-1040 provides all the necessary security you need by allowing the administrator to configure user access rights to the printer. It supports a wide range of network operating systems including: Windows 95/98/ME/NT 4.0/2000/XP/Vista, Apple MacOS, Linux, HP-UX, SunOS, Solaris, SCO Unix, IBM AIX and NetWare 5.x native NDS. Enjoy the fl exibility and compatibility that this print server offers.
REMOTE PRINTING SUPPORT
The DPR-1040 supports the Internet Printing Protocol (IPP), enabling remote users to output files to their office printer even when they are away from the site. HP PJL protocol is also supported for bi-directional network  printer communication, providing network administrators with critical information about the network printer. Regardless of where you are, with this print server never again worry about being unable to print out important files.
מאפיינים כללים
תקנים
  • IEEE 802.3
  • IEEE 802.3u
  • USB 2.0
  • IEEE 802.11b
  • IEEE 802.11g
    ממשקים
  • ממשק אלחוטי 802.11b/g LAN
  • 1 פורט USB 2.0
  • 1 פורט 10/100Base-TX Ethernet LAN
תדר
  • 2.4 - 2.462 Ghz
    מהירות העברת נתונים
  • 54,48,36,24,18,12,11,9,6,5.5,2,1Mbps
סוג אנטנה
  • PIFA
אבטחה אלחוטית
  • 64/128 ביט הצפנת WEP
  • WPA/WPA2
  • תמיכה ב WPS
ניהול
  • ניהול מתבצע דרך דפדפן
  • שרת DHCP ולקוח
  • תוכנה להגדרה וניהול
תמיכה במערכות הפעלה
  • Windows Vista/7/XP
  • MAC OS X 10.4.x
תקנים
הורדות
איורים
DPR-1040
מראה מאחורה
מראה מקדימה
דף מידע
ראה גם
