תאור
FOUR PRINTERS, LESS WAITING
The D-Link RangeBooster G™ Multifunction Print Server (DPR-1260) is D-Link's most versatile and easiest to use Print Server yet. When attaching multiple devices, the Quick Installation Wizard takes all the work out of setting up the Print Server and configuring the attached printers. Multiple ports give you the option of adding multiple printers or multifunction printers to the network. RangeBooster G technology improves wireless performance, reducing the time required to send print jobs to the print server.
PRINTERS AND MULTIFUNCTION PRINTERS WELCOME*
Tested with over 100 different printer models, this Print Server offers class-leading device compatibility*. Using the web-based interface, easily scan documents and photos directly to your computer. This print server is compatible with a wide range of USB multifunction printers including the scanning functionality of select multifunction printers and is backward compatible with USB 1.1/1.0 printers.*
WIRELESS EXPANDABILITY
The Ethernet port on the Print Server can be used as a wireless bridge. This provides wireless connectivity for any Ethernet-enabled device, such as a computer, Digital Video Recorder (DVR), or Network-Attached Storage (NAS) to the wireless network.
WHAT THIS PRODUCT DOES
D-Link's new RangeBooster G™ Multifunction Print Server (DPR-1260) allows you to wirelessly share up to 4 USB Multifunction Printers (MFP) on your network. This innovative new print server allows multiple users to print using one of the four connected MFPs*. By supporting multiple printers over a wireless connection, this new print server is the ideal solution for your home, classroom, or office.
