DIR-806A/A1EOL EOS
Aprašymas
Wireless Interface
Using the DIR-806A device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 733Mbps*).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
Router Mode
You are able to connect DIR-806A switched to the router mode to a cable or DSL modem or to a private Ethernet line and use a high-speed Internet connection to successfully fulfill a wide range of professional tasks.
Access Point Mode
You are able to use DIR-806A switched to the access point mode to create a wireless network or to connect to a wired router.
“Client” Function
The “client” function in the router mode allows using DIR-806A as a WISP repeater, in the access point mode as a wireless client and a wireless repeater.
Security
The wireless router DIR-806A includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Easy configuration and update
You can configure the settings of the wireless router DIR-806A via the user-friendly web-based interface (the interface is available in several languages).
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
*Up to 300Mbps for 2.4GHz and up to 433Mbps for 5GHz.
Bendros charakteristikos
Hardware
Interfaces
• 10/100BASE-TX WAN port
• 4 10/100BASE-TX LAN ports
• Micro-USB 2.0 type A port for power supply
LEDs
• Operating mode
• WLAN
• Internet
• 4 LAN LEDs
Buttons
• RESET/WPS button to restore factory default settings and set up secure wireless connection
Antenna
• Two external detachable dual band antennas (5dBi gain)
Power connector
• Power input connector (DC)
Software
Operation Modes
• Router mode
• Access point mode
WAN connection types
• PPPoE
• Static IP / Dynamic IP
• PPPoE + Static IP / Dynamic IP
• PPTP/L2TP + Static IP
• PPTP/L2TP + Dynamic IP
Network functions
• DHCP server/relay
• DNS relay
• Dynamic DNS
• Static IP routing
• IGMP Proxy
• RIP
• Support of UPnP IGD
• Support of VLAN
• Flow control
• WAN ping respond
• Support of SIP ALG
• Support of RTSP
Firewall functions
• IP filter
• MAC filter
• URL filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
VPN
• IPSec/PPTP/L2TP/PPPoE pass-through
Management
• Local and remote access to settings through TELNET/WEB (HTTP)
• Multilingual web-based interface for configuration and management
• Support of remote logging
• Ping function
• Traceroute utility
• TR-069 client
Wireless Module Parameters
Standards
• IEEE 802.11a/n/ac
• IEEE 802.11b/g/n
Frequency range
• 2400 ~ 2483.5MHz
• 5150 ~ 5350MHz
Wireless connection security
• WEP
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• Support of MBSSID
• “Client” function in the router mode (WISP repeater)
• “Client” function in the access point mode (wireless network client, wireless network repeater)
• WMM (Wi-Fi QoS)
• Information on connected Wi-Fi clients
• Advanced settings
Wireless connection rate
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n (2.4GHz/5GHz): from 6.5 to 300Mbps (from MCS0 to MCS15)
• IEEE 802.11ac (5GHz): from 6.5 to 433Mbps (from MCS0 to MCS9)
Transmitter output power
• 802.11a (typical at room temperature 25 °C)
15dBm (+/-1.5dB) at 6, 9, 12, 18, 24, 36, 48Mbps
14dBm (+/-1.5dB) at 54Mbps
• 802.11b (typical at room temperature 25 °C)
15dBm (+/-1.5dB) at 1, 2, 5.5, 11Mbps
• 802.11g (typical at room temperature 25 °C)
15dBm (+/-1.5dB) at 6, 9, 12, 18, 24, 36, 48, 54Mbps
• 802.11n (typical at room temperature 25 °C)
2.4GHz, HT20
15dBm (+/-1.5dB) at MCS0/1/2/3/4/5/6/7/8/9/10/11/12/13/14/15
2.4GHz, HT40
5GHz, HT20
5GHz, HT40
• 802.11ac (typical at room temperature 25 °C)
HT20
HT40
HT80
14dBm (+/-1.5dB) at MCS8
13dBm (+/-1.5dB) at MCS9
Receiver sensitivity
• 802.11a (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
-82dBm at 6Mbps
-81dBm at 9Mbps
-79dBm at 12Mbps
-77dBm at 18Mbps
-74dBm at 24Mbps
-70dBm at 36Mbps
-66dBm at 48Mbps
-65dBm at 54Mbps
• 802.11b (typical at PER = 8% (1000-byte PDUs) at room temperature 25 °C)
-84dBm at 1Mbps
-84dBm at 2Mbps
-82dBm at 5.5Mbps
-79dBm at 11Mbps
• 802.11g (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
-82dBm at 6Mbps
-81dBm at 9Mbps
-79dBm at 12Mbps
-77dBm at 18Mbps
-74dBm at 24Mbps
-70dBm at 36Mbps
-66dBm at 48Mbps
-65dBm at 54Mbps
• 802.11n (typical at PER = 10% (1000-byte PDUs))
2.4GHz, HT20
-91dBm at MCS0
-88dBm at MCS1
-86dBm at MCS2
-83dBm at MCS3
-79dBm at MCS4
-75dBm at MCS5
-74dBm at MCS6
-73dBm at MCS7
-88dBm at MCS8
-85dBm at MCS9
-83dBm at MCS10
-80dBm at MCS11
-76dBm at MCS12
-72dBm at MCS13
-71dBm at MCS14
-70dBm at MCS15
2.4GHz, HT40
-88dBm at MCS0
-85dBm at MCS1
-83dBm at MCS2
-80dBm at MCS3
-76dBm at MCS4
-72dBm at MCS5
-71dBm at MCS6
-70dBm at MCS7
-85dBm at MCS8
-82dBm at MCS9
-80dBm at MCS10
-77dBm at MCS11
-73dBm at MCS12
-69dBm at MCS13
-68dBm at MCS14
-67dBm at MCS15
5GHz, HT20
-82dBm at MCS0
-79dBm at MCS1
-77dBm at MCS2
-74dBm at MCS3
-70dBm at MCS4
-66dBm at MCS5
-65dBm at MCS6
-64dBm at MCS7
5GHz, HT40
-79dBm at MCS0
-76dBm at MCS1
-74dBm at MCS2
-71dBm at MCS3
-67dBm at MCS4
-63dBm at MCS5
-62dBm at MCS6
-61dBm at MCS7
• 802.11ac (typical at PER = 10% (1000-byte PDUs))
HT20
-82dBm at MCS0
-79dBm at MCS1
-77dBm at MCS2
-74dBm at MCS3
-70dBm at MCS4
-66dBm at MCS5
-65dBm at MCS6
-64dBm at MCS7
HT40
-79dBm at MCS0
-76dBm at MCS1
-74dBm at MCS2
-71dBm at MCS3
-67dBm at MCS4
-63dBm at MCS5
-62dBm at MCS6
-61dBm at MCS7
HT80
-76dBm at MCS0
-73dBm at MCS1
-71dBm at MCS2
-68dBm at MCS3
-64dBm at MCS4
-60dBm at MCS5
-59dBm at MCS6
-58dBm at MCS7
-53dBm at MCS8
-51dBm at MCS9
Modulation schemes
• 802.11a: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11ac: BPSK, QPSK, 16QAM, 64QAM, up to 256QAM with OFDM
Physical Parameters
Dimensions (L x W x H)
• 116 x 81.7 x 21.5 mm (4.57 x 3.22 x 0.85 in)
Weight
• 390 g (0.86 lb)
Operating Environment
Power
• Output: 5V DC, 1.2A
Temperature
• Operating: from 0 to 40 °C
• Storage: from -20 to 65 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 5% to 95% (non-condensing)
Delivery Package
• Router DIR-806A
• Power adapter DC 5V/1.2A
• Ethernet cable
Sertifikatai
Informacija užsakymui
DIR-806A Wireless AC750 Dual Band Router & Access Point
