Ātrā meklēšana
Produkta iespējas:
Eight 10/100/1000Base-T PoE Port EasySmart Switch
Īpašības:
Size
• Desktop
Number of Ports
• 8 10/100/1000 PoE Gigabit ports
Port Functions
• IEEE 802.3 compliant
• IEEE 802.3u compliant
• Supports half/full-duplex operation (half at 10/100Mbps, full at 1000Mbps)
• Auto-negotiation
• Auto MDI/MDIX
• IEEE 802.3x Flow Control supports Full-Duplex mode
• IEEE 802.3az compliant
Performance
Switching Capacity
• 16Gbps
Maximum Forwarding Rate
• 11.9Mpps
MAC Address Table Size
• 8K Entries
Packet Buffer
• 2Mbits
Flash Memory
• 2MB
PoE
PoE Standard
• 802.3af
PoE Capable Ports
• Port 1 to 8: 15.4W
• Max. 15.4 W on 4 10/100/1000Mbps ports
• Max. 8W on 8 10/100/1000Mbps ports
PoE Power Budget
64W
LEDs
• Power (per device)
• PoE Max.
• Link/Activity/Speed (per port)
Power Consumption
Standby Mode
• 2.0 watts
Maximum
• 78.8 watts
Software Features
VLAN
• Port-based VLAN
• 802.1Q Tagged VLAN
• Surveillance VLAN
• Voice VLAN
• Management VLAN
• VLAN Group
  - Supports 32 static VLAN groups
  - Max. 4094 VIDs
L2 Features
• MAC Address Table: 8K
• Flow Control
  - 802.3x Flow Control
  - HOL Blocking Prevention
• Jumbo Frames up to 9216 Bytes
• IGMP Snooping
  - IGMP v1/v2 Snooping
  - Supports 32 Groups
• Link Aggregation
  - 2 groups, 2-4 ports per group
• Loopback Detection
• Cable Diagnostics
• Port Mirroring
  - One-to-One
• Statistics
  - Tx Ok
  - Tx Error
  - Rx Ok
  - Rx Error
Quality of Service (QoS)
• 802.1p Quality of Service
• 4 queues per port
• Queue Handling
  - Strict
  - Weighted Round Robin (WRR)
• Bandwidth Control
  - Port-based (Ingress/Egress, min. granularity 8Kb/s)
Security
• Static MAC Address
  - Up to 32 entries
• Broadcast/Multicast/Unknown Unicast Storm Control
Management
• Web-based GUI (Supports IPv4)
• SmartConsole Utility
D-Link Green
• Power Saving by
  - Link Status
  - Cable Length
• Compliant with IEEE 802.3az Energy Efficient Ethernet
• Compliant with RoHS 6
RFC Standard List
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 951 BootP Client
• RFC 1542 BootP/DHCP client
• RFC 1945 HTTP/1.0
• RFC 2647 802.1p
Fiziskie raksturlielumi
Power Input
• 100 to 240 V AC
• 50 to 60 Hz External Power Adapter
MTBF
• 708,219 hours
Acoustics
• 0dB
Heat Dissipation
• 268.87BTU/hr
Weight
• 0.706kg
Dimensions
• 190 x 120 x 38mm
Ventilation
• Fanless
Operating Temperature
• 0 to 50°C
Storage Temperature
• -10 to 70°C
Operating Humidity
• 10% to 95% non-condensing
Storage Humidity
• 5% to 95% non-condensing
EMI
• FCC Class A, CE Class A, VCCI Class A, ICES-003, C-Tick
Safety
• cUL, CE LVD
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
