Ātrā meklēšana
Produkta iespējas:
EasySmart Switches
Īpašības:
Size
11-inch Desktop/Rackmount Size, 1U Height
Number of Ports
16 10/100/1000 Gigabit ports
Port Functions
- IEEE 802.3 compliant
- IEEE 802.3u compliant
- Supports half/full-duplex operation (half at 10/100 Mbps, full at 1000 Mbps)
- Auto-negotiation
- Auto MDI/MDIX
- IEEE 802.3x Flow Control supports Full-Duplex mode
- IEEE 802.3az compliant
Performance
Switching Capacity
32 Gbps
Maximum Forwarding Rate
23.81 Mpps
MAC Address Table Size
8K Entries
Packet Buffer
3.5 Mbits
Flash Memory
2 MB
LEDs
- Power (per device)
- Link/Activity/Speed (per port)
Power Consumption
- Standby Mode: 5.64 watts
- Maximum: 11.29 watts
Software Features
VLAN
• Port-based VLAN
• 802.1Q Tagged VLAN
• Surveillance VLAN
• Voice VLAN
• Management VLAN
• VLAN Group
  • Supports 32 static VLAN groups
  • Max. 4094 VIDs
L2 Features
• MAC Address Table: 8K
• Flow Control
  • 802.3x Flow Control
  • HOL Blocking Prevention
• Jumbo Frames up to 9216 Bytes (DGS-1100-05/08/08P)
• IGMP Snooping
  • IGMP v1/v2 Snooping
  • Supports 32 Groups
• Static Trunk
  • DGS-1100-05: 1 group, 2-4 ports per group
  • DGS-1100-08/08P: 2 groups, 2-4 ports per group
  • DGS-1100-16/24: 8 groups, 2-4 ports per group
• Loopback Detection
• Cable Diagnostics
• Port Mirroring
  • One-to-One
  • Many-to-One (DGS-1100-16/24)
• Statistics
  • Tx Ok
  • Tx Error
  • Rx Ok
  • Rx Error
Quality of Service (QoS)
• 802.1p Quality of Service
• 4 queues per port
• Queue Handling
  • Strict
  • Weighted Round Robin (WRR)
• Bandwidth Control
  • Port-based (Ingress/Egress, min. granularity 64 Kb/s)
Security
• Static MAC Address
  • DGS-1100-05/08/08P: up to 32 entries
  • DGS-1100-16/24: up to 128 entries
• Broadcast/Multicast/Unknown Unicast Storm Control
Management
• Web-based GUI (Supports IPv4)
• SmartConsole Utility
D-Link Green
• Power Saving by
  • Link Status
  • Cable Length
  • Compliant with IEEE 802.3az Energy Efficient Ethernet
  • Compliant with RoHS 6
RFC Standard List
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 951 BootP Client
• RFC 1542 BootP/DHCP client
• RFC 1945 HTTP/1.0
• RFC 2647 802.1p
• RFC 2236, 4451 IGMP Snooping
Fiziskie raksturlielumi
Power Input
100 to 240 V AC
50 to 60 Hz Internal Universal Power Supply
MTBF
988,205 hours
Acoustics
0 dB
Heat Dissipation
38.52 BTU/hr
Weight
1.5 kg
Dimensions
280 x 180 x 44 mm
Ventilation
Fanless
Operating Temperature
0 to 40 °C
Storage Temperature
-10 to 70 °C
Operating Humidity
10% to 95% non-condensing
Storage Humidity
5% to 95% non-condensing
EMI
FCC Class A, CE Class A, VCCI Class A, ICES-003, C-Tick
Safety
cUL, CE LVD
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
