Apraksts
The D-Link XFP module provides high-speed 10-Gigabit connection on the secure fiber cable. It provides a single or dual XFP slots and can be slid into an open slot of a D-Link Gigabit switch. A number of 10Gigabit transceivers are available for selection for installation in the XFP slot. Data transfer is operated in the full-duplex mode at 20 Gigabits per second on either the multi-mode or single-mode fiber network cable, depending on the type of transceiver being installed.
The D-Link XFP module allows flexible deployment of 10-Gigabit connection and is ideal for bandwidth-hungry applications that can meet greater cable distances and low signal interference requirements in the Local Area Network, Wide Area Network and Metropolitan Area Network.
Īpašības
Number of XFP Slots
2 XFP slots
Data Rate & Operation
20 Gigabit per second (full-duplex)
Switch Compatibility
DXS-3300 series switches
Transceiver Support
- DEM-421XT (up to 300 m on multi-mode fiber cable)
- DEM-422XT (up to 10 km on single-mode fiber cable)
- DEM-423XT (up to 40 km on single-mode fiber cable)
Sertifikāti
Informācija pasūtījumam
DEM-420X Module
- 2 XFP Slots
- Compatible With DXS-3300 Series Gigabit Switches
