DES-6506EOL EOS
Apraksts
The DES-6506 is a 24-port Ethernet patch panel for the DES-6500 chassis switch. This patch panel provides 2 sets of RJ-21 to RJ-45 connectors, each supporting 12 connections. The patch panel is designed to work with the 24-port 10/100BASE-TX DES-6510 module, also equipped with RJ-21 connectors. System integrators wishing to set up a high port density network can install the DES-6510 modules in the DES-6500 chassis together with the DES-6506 patch panels.
Īpašības
Standards
- IEEE 802.3 10BASE-T
- IEEE 802.3u 100BASE-TX
- ANSI/IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control
Topology
Star
Network Cable
Ethernet Cat. 5 cable (max. 100 m)
Number of Ports
24 10/100BASE-TX Ethernet ports
Connectors
- 2 RJ-21 connectors, each supports 12 Ethernet connections
- 24 RJ-45 connectors
Box Includes
- DES-6506 24-port Ethernet patch panel
- Quick Installation Guide
Sertifikāti
Informācija pasūtījumam
DES-6506 24-Port Ethernet Patch Panel for DES-6500 Chassis Switch
