Ātrā meklēšana
Produkta iespējas:
Managed 8-Port 10/100/1000 L2 Switch with 2 1000Base-T/SFP Combo Ports
EOL
Īpašības:
Device Interfaces
+  8 10/100/1000BASE-T Gigabit Ports
+  2 Combo 10/100/1000BASE-T/SFP Ports
+  RS-232 DB-9 Console Port
Performance
+ MAC Address Table: 8K
+ Switch Capacity: 20Gbps
+ Maximum Packet Forwarding Rate: 14.88Mpps
+ Switching Method: Store and Forward
+ Packet Buffer Memory Size: 128Kbytes
Flow Control
+  802.3x Standard in Full Duplex Mode
+  Back Pressure in Half Duplex Mode
SOFTWARE FUNCTIONS
Stackability
+ Virtual Stacking
  Support D-Link Single IP Management
  Up to 32 devices per virtual stack
L2 Features
+ Flow Control
  802.3x Flow Control
  HOL Blocking Prevention
+ Jumbo Frame up to 10,240 Bytes
+ IGMP snooping
  IGMP v1/v2/v3 Snooping
  Support 256 Groups
  IGMP Snooping Fast Leave
+ MLD Snooping
  MLD v1/v2 Snooping
  Support 256 Groups
+ Spanning Tree
  802.1D STP
  802.1w RSTP
  802.1s MSTP
+ Per port / per device BPDU fltering
+ Loopback Detection
+ 802.3ad Link Aggregation
  Max. 5 Groups per device/8 Ports per group
+ Port Mirroring
  Support One-to-One
  Many-to-One
  Flow-based Mirroring
VLAN
+ VLAN Group
  Max. 4K Static VLAN Groups
  Max. 255 Dynamic VLAN Groups
+ 802.1Q Tagged VLAN
+ GVRP
+ 802.1v Protocol VLAN
QoS (Quality of Service)
+ 802.1p Class of Service
+ 8 queues
+ Queue Handling
  Strict
  Weighted Round Robin (WRR)
+ CoS based on
  Switch Port
  VLAN ID
  802.1p Priority Queues
  MAC Address
  IPv4/IPv6 Address
  DSCP
  TCP/UDP Port
  Protocol Type
  IPv6 Traffc Class
  IPv6 Flow Label
  User-Defned Packet Content
+ Bandwidth Control
  Port-based (Ingress/Egress, min. granularity 512Kb/s)
  Flow-based (Ingress, min. granularity 64Kb/s)
ACL (Access Control List)
+ Up to 200 access rules
+ ACL Based on
  802.1p Priority
  VLAN ID
  MAC Address
  IPv4/IPv6 Address
  DSCP
  Protocol Type
  TCP/UDP Port Number
  IPv6 Traffc Class
  IPv6 Flow Label
  User Defned Packet Content
+ Time-based ACL
+ CPU Interface Filtering
Security
+ SSH v2
+ SSL v1/v2/v3
+ Port Security: up to 16 MAC address per port
+ Broadcast/Multicast/Unicast Storm Control
+ Traffc Segmentation
+ IP-MAC-Port Binding
  Support 128 address binding entries per device
  Support ARP / ACL Mode
+ D-Link Safeguard Engine
+ Microsoft
® NAP (Supports IPv4/IPv6)
AAA
+ 802.1X
  Port-Based Access Control
  Host-Based Access Control
  Dynamic VLAN Assignment
+ Web-Based Access Control (WAC)
+ MAC-Based Access Control (MAC)
+ Guest VLAN
+ Authentication for Management Access Support RADIUS/TACACS+
+ RADIUS Accounting
Management
+ Web-based GUI (Supports IPv4/IPv6)
+ Command Line Interface (CLI)
+ Telnet Server/Client (Supports IPv4/IPv6)
+ TFTP Client (Supports IPv4/IPv6)
+ ZModem
+ SNMP v1/v2c/v3
  SNMP over IPv6
+ SNMP Trap
+ System Log
+ RMON v1
  Support 1,2,3,9 Groups
+ RMON v2
+ Support ProbeConfg Group
+ BootP/DHCP Client
+ DHCP Auto-Confguration
+ DHCP Relay
+ DHCP Relay Option 82
+ Dual Image
+ Dual Confguration
+ CPU Monitoring
+ SNTP
+ ICMPv6
+ IPv6 Neighbor Discovery
MIB/IETF® Standard
+ RFC1213 MIB-II
+ RFC1493 Bridge MIB
+ RFC1907 SNMPv2 MIB
+ RFC1757, 2819 RMON MIB
+ RFC2021,RMONv2 MIB
+ RFC1643,2358,2665 Ether-like MIB
+ RFC2674 802.1p MIB
+ RFC2233, 2863 IF MIB
+ RFC2618 RADIUS Authentication Client MIB
+ RFC2925 Ping & Traceroute MIB
+ D-Link Private MIB
+ RFC768 UDP
+ RFC783 TFTP
+ RFC791 IP
+ RFC792 ICMP
+ RFC793 TCP
+ RFC826 ARP
+ RFC854 Telnet
+ RFC951, 1542 BootP
+ RFC2068 HTTP
+ RFC2138 RADIUS
+ RFC2139,2866 RADIUS Accounting
+ RFC2620, RADIUS Accounting Client MIB
+ RFC1492 TACACS
+ RFC1157 SNMPv1
+ RFC1901, 1908 SNMPv2c
+ RFC2570,2575 SNMPv3
Fiziskie raksturlielumi
Diagnostic LEDs
+ Per Device: Power, Console
+ Per 10/100/1000BASE-T Port: Link/Activity/Speed
+ Per SFP Slot: Link/Activity/Speed
Power
+ AC Input Power: 100-240 VAC, 50-60 Hz
Dimensions
+  280 (W) x 180 (D) x 43 (H)
Ventilation
+ One Fan (Default off)
Temperature
+ Operating Temperature: 0 ~ 40C
+ Storage Temperature: -40 ~ 70C
Humidity
+  5%-95% non-condensing
MTBF
+  354,222 Hours
Power Consumption
+  28.9Watts (Max.)
EMI
+  FCC, CE, VCCI Class A, C-Tick
Safety
+ UL, CB Report
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
