Ātrā meklēšana
Novecojis modelis - noņemts no ražošanas
Produkta iespējas:
8-Port Stackable KVM Switch
Apraksts:
The D-Link DKVM-8E Keyboard, Video, and Mouse (KVM) switch allows you to take control of eight different server PCs using just one keyboard, monitor, and mouse. It's easy to use, powerful, and scaleable. In addition, eight DKVM-8E switches (banks) can be stacked together to control up to 64 PCs.
The DKVM-8E utilizes advanced microprocessor emulation to intelligently manage each KVM port. This allows simultaneous boot-up of all the attached PCs.
The DKVM-8Es intelligent microprocessors save CAPSLOCK, NUM LOCK, and SCROLL LOCK status for each PC. It supports VGA, SVGA and MultiSync monitors at up to 1920 x 1440 resolution. Support for AT type PC with serial mouse ports are included using a mouse conversion technology.
The DKVM-8E's on-screen display (OSD) provides a friendly interface and features naming and selecting of a specific PC, as well as password protection for advanced security. Hot-plug, auto-scan, audible feedback and keyboard "Hot Keys" make this device simple to use and manage. Also, two control buttons located on the front panel allow you to select a specific PC among the attached DKVM-8E and all stacked switchs.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu
