Produkta iespējas:
4-port KVM Switch |
Apraksts:
The DKVM-4K 4-port KVM switch is a cost-effective KVM solution for office users and business. This switch allows you to easily control 4 different PCs from a single set of keyboard, mouse, and VGA monitor. The switch provides many easy to use features and is perfect for MIS, network administrators and business users.
Cost-effective for PC Users
If you need to control several computers at the same time (such as in a computer room), the DKVM-4K saves you the money and space by allowing you to control your the computers from a set of keyboard, monitor and mouse. You may have a better, bigger monitor and want to connect all 4 PCs to it, the DKVM-4K allows you to do this.
High Performance and Easy Management of Port Traffic/Server Control
The DKVM-4K allows you to manage port traffic and boot up the attached PCs. A control button located on the top of the DKVM-4K gives you one touch access to your attached PCs. Featuring hot-plug, auto-scan, keyboard hot-keys and audible feedback, this switch makes it simple to manage all of your computers.
Status Save and High Resolution Support
The DKVM-4K supports VGA, SVGA, and MultiSync monitors at up to 2048 x 1536 resolution. Support for Microsoft IntelliMouse is provided. |
Skatiet arī
