Ātrā meklēšana
Produkta iespējas:
ShareCenter™ 1-Bay Network Storage
EOL EOS
Īpašības:
Standards
• IEEE 802.3
• IEEE 802.3ab
• IEEE 802.3u
• TCP/IP
• CIFS/SMB
• NFS
• AFP
• WebDAV
• DDNS
• DHCP Client
• FTP over SSL/TLS, FXP
• HTTP/HTTPS
• LLTD
• PnP-X
• UPnP AV
• USB 2.0
• Bonjour
• NTP
• MTP/PTP
• SMTP
• UPnP Port Forwarding
Supported Hard Drives
• Hard drive type: SATA II 3.5-inch internal**
• Hard drive capacity: 3 TB*** and beyond
Ports
• 10/100/1000 Gigabit Ethernet port
• USB 2.0 Host port
• Power
LEDs
• Power
• USB
• HDD
• LAN (on LAN port)
Disk Management
• Hard Drive Format: EXT4
• Scandisk
• S.M.A.R.T.
• Support Advanced Format HDD
Account Management
• User account management
• Group account management
• User/Group Quota management
• Network Access management
File Sharing
• Max. User Accounts: 512 users
• Max. Groups: 64 groups
• Max. Shared Folders: 128 folders (without BT)
• Max. Concurrent Connections: 64 connections
• Max. Concurrent FTP Connections: 10 connections
Remote File Sharing
• Web File Server
• FTP Server
• WebDAV
Backup Management
• Schedule Backup from PC to NAS (by Bundled Backup Software: ShareCenter Sync)
• Schedule Local Backup
• Schedule Remote Backup (Rsync)
• Apple Time Machine support
• Cloud Backup (Amazon S3)
• USB Backup (External Storage and Digital Camera (MTP))
• USB Copy Button
Media Streaming
• Complies with DLNA
• Support for PS3/Xbox 360
• Support for UPnP AV files greater than 4 GB
• Compatible with D-Link’s new media players (including the Boxee Box)
• iTunes Server
Download Management
• HTTP/FTP schedule download
• Peer to peer (P2P) download
USB Port Support
• Print Server
• External Storage
• Digital Camera (MTP/PTP)
Device Management
• Internet Explorer 7 or higher, Mozilla Firefox 3 or higher, Apple, Safari 4 or higher, Google Chrome 3 or higher, or Opera 10 or higher
• D-Link Storage Utility
• E-mail Notification
• SMS Notification
• Resource Monitor
• System/FTP log (Syslog Client)
• Yahoo! Widget
• ISO Mount management
• Network Recycle Bin
Physical Parameters
Power Management
• Power Saving mode
• Auto Power Recovery
• Schedule Power on/off
• Smart Fan Control
• D-Link Green Ethernet
Power Supply
• External power supply
• DC 12 V / 2 A switching
Power Consumption
• Normal mode: 14.9 W
• Sleep mode: 4.3 W
Operating Temperature
• 0° to 40°C
Storage Temperature
• -20° to 70°C
Operating Humidity
• 5% to 90% (Non-condensing)
Dimensions (W x D x H)
• Device: 50 x 141.3 x 173 mm
• Packaging: 274 x 208 x 118 mm
Weight
• Without hard drive: 568 g
Multilingual Support
• Samba: Unicode
• FTP Server: Chinese (Simplified), Chinese (Traditional), Croatian,
Cyrillic (Kyrgyz Republic), Czech, Danish, Dutch, English, Finnish, French, German, Greek, Hebrew, Hungarian, Italian, Korean, Korean, Norwegian, Polish, Portuguese, Romanian, Russian, Slovenian, Spanish, Swedish, Turkish, Turkish, Unicode
Certifications
• CE
• FCC
• C-TICK
• PCT
• DLNA Certified
• D-Link Green Certified
* D-Link cannot guarantee full compatibility or proper playback with all codecs. Playback capability depends on the Codec support of the UPnP AV media player.
** Hard drive may not be included. An internal SATA drive is required to store or share files. This device may not work with older generation SATA drives. For a list of SATA drives that have been tested to work with the DNS-315, visit D-Link support web sites.
*** Maximum storage may change due to vendor’s increases in hard drive capacities.
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
