DCS-7410EOL EOS
Securicam Day and Night Outdoor Network Camera
Apraksts
DAY & NIGHT POWERFUL SURVEILLANCE
The DCS-7410 and DCS-7510 are day and night outdoor cameras with built-in infrared LEDs. These cameras can detect moving objects in total darkness at distances of up to 30 or 50 meters. Equipped with a high-resolution Sony CCD image sensor, these cameras provide you with excellent image quality and a high level of detail. The built-in Infrared Cut Removable (ICR) filter in the DCS-7510 allows the camera to capture images in both good light and low-light conditions. Embedded with a powerful SoC (System-on-Chip), the cameras provide high-quality, real-time video compression in MPEG-4 and motion JPEG formats. These
features make the DCS-7410/7510 an ideal solution for 24-hour surveillance.
VARIFOCAL LENS FOR FLEXIBLE SURVEILLANCE
The DCS-7510 is equipped with a varifocal 9 - 22 mm lens that allows you to manually change the focal length. You will get a wider field of view with a shorter focal length, whereas a longer focal length narrows the field of view and allows you to zoom in further. The focus and zoom controls are located on the outside of the camera case for easy adjustment. This camera also has an auto-iris that automatically adjusts the exposure according to lighting conditions for optimum picture quality.
WIRED PoE ACCESS
For easy installation in high places, the cameras comes with built-in 802.3af compliant Power over Ethernet (PoE), giving users the freedom to place the camera anywhere by eliminating the need for a nearby power outlet.
VIEW LIVE VIDEO FROM A 3G MOBILE PHONE 3
A live feed from the camera can be accessed on a 3G mobile network by using a compatible mobile phone or PDA with a 3G video player. Users have a flexible and convenient way to remotely monitor a home or office in real time from anywhere within their 3GPP service area.
WEATHERPROOF HOUSING
The cameras are housed in an IP66 certified weatherproof casing which protects against rain and dust. An adjustable top shield guards the camera sensor from direct sunlight while providing ventilation. The wire-in-bracket design assembles tightly to protect the cables not only from outdoor wear and tear, but also from criminal acts such as intentional cable cutting.
INTELLIGENT & EASY To USE
The bundled D-ViewCam software allows you to manage and record videos to a Network Attached Storage (NAS) device such as the D-Link DNS-323. Alternatively, you can record videos to a Network Video Recorder (NVR) such as the D-Link DNS-722-4 or DNS-726-4. These NAS and NVR devices support RAID-1 for you to back up your recorded videos. Playback of recorded videos consumes less time with triggered event browsing and smart database searching features. You can also connect the cameras to I/o sensors, and configure the system to send automated e-mail notifications for unusual events.
Īpašības
CAMERA SPECIFICATIONS
+ Built-in 1/3” SoNY interlaced CCD sensor
+ IR LEDs: 30m illumination distance
+ Lens: Focal Length 12mm, F1.4
+ Minimum illumination: 0.7 lux @ F1.4
+ Electronic shutter:
NTSC: 1/60 - 1/100,000 sec.
PAL: 1/50 - 1/110,000 sec.
VIEW ANGLE
+ Horizontal: 22°
+ Vertical : 17°
LED INDICATORS
+ Link & Activity
+ Power
RESET BUTTON
Reset to factory default settings
EXTERNAL DEVICE INTERFACE
+ 2 Inputs:
- Photo Relay
- Active High 12 V, +/-3 V, Dropout: 0 VDC
+ 1 output:
- Photo Relay
- Closed-circuit current: AC 70mA or DC 100mA; 400hm
- Open circuit voltage: 240 VAC or 350 VDC
- Power output: 12 V DC 200 mA
+ RS-485 connector for external PT devices
MEMORY
+ SDRAM: 64 MBytes
+ Flash Memory: 8 MBytes
IR FUNCTIONS
+ IR LED: 8 pcs (with condenser)
+ IR Wavelength: 850 nm
+ IR Status: Under 10 lux by photo sensor auto control
+ IR Distance: Up to 30 m
VIDEO FEATURES
+ Adjustable image size, quality, and bit rate
+ Time stamp and text overlays
+ Configurable motion detection windows
+ Adjustable AGC level, AWB, and AES
VIDEO RESOLUTION
MPEG-4/MJPEG video resolution up to D1
VIDEO BIT RATE
64 K to 2 M
VIDE ALGORITHM SUPPORT
+ JPEG for still images
+ MPEG4/MJPEG dual-format compression
+ Simultaneous dual-streaming
+ Supports up to 4 video profiles simultaneously
+ Supports 3GPP mobile surveillance
DIGITAL ZOOM
16X
AUDIO
+ Sampling Rate:
+ GSM-AMR: 12.2 Kbps
+ PCM: 8 Kbps
+ Full duplex audio communication
NETWORK PROTOCOL SUPPORT
IPv4, ARP, TCP/IP, RTSP, RTP, RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS, PPPoE, Samba Client, 3GPP
NETWORK INTERFACE
+ IEEE 802.3/802.3u 10/100BASE-TX Ethernet port
+ Supports full-duplex operations
+ Supports 802.3x Flow Control in full-duplex mode
+ Supports IEEE 802.3af PoE
REMOTE MANAGEMENT
+ Configurable via web browser
+ Take snapshots/video clips and save to local hard drive via web browser or save directly to a NAS device
SECURITY
+ Administrator and user group protected
+ Password authentication
D-VIEWCAM SOFTWARE FUNCTIoNS
+ Remote management/control of up to 32 cameras
+ Viewing of up to 32 cameras on one screen
+ Management functions are provided in the web interface
+ Scheduled, motion triggered, or manual recording options
SYSTEM REQUIREMENTS
+ Operating System: Microsoft Windows 7 / Vista / XP, Mac oS X 10.3 or higher
+ Browser: Internet Explorer 6 or higher, Firefox 2.0 or higher,
+ Safari 2.0 or higher
Sertifikāti
Informācija pasūtījumam
DCS-7410 Securicam Day and Night Outdoor Network Camera
