Apraksts
DESIGNED FOR POWERFUL SURVEILLANCE
The DCS-3415 18x PoE Network Camera is designed to target high-end surveillance market. An 18x optical zoom progressive scan CCD module can capture
superb vivid images of moving objects that traditional interlaced scanning techniques cannot achieve and effectively reduces motion blur and distorted, jagged
edges of recorded images. The DCS-3415 uses its SoC (system-on-chip) to provide high quality real-time video compression in MPEG-4 and Motion JPEG
formats. Furthermore, it supports MPEG4 multicast streaming, letting users view content by subscribing to a multicast IP address on the network. The DCS-3415
can also be connected to a variety of external devices such as IR-sensors, switches and alarm relays making it a versatile yet ideal solution for high quality
viewing and reliable recording during the day or night.
WATCH LIVE VIDEOS FROM A 3G DEVICE
The live camera feed of the camera can be pulled from the 3G cellular network by using a compatible cell phone or PDA with a 3G video player. Users are
offered a flexible and convenient way to remotely monitor a professional environment such as an office or factory, anywhere within the 3GPP service area.
EASY TO SETUP WITH WIRED PoE ACCESS
For effective surveillance in and around a building, the DCS-3415 comes with a built-in 802.3af compliant Power Over Ethernet (PoE) module for flexible deployment.
It can connect directly to a PoE Ethernet switch without the need for a power cable, providing users the freedom to place the camera anywhere they want,
including high walls and hard to see locations.
SMART & EASY TO USE
D-Link’s D-ViewCam software allows you to view up to 32 cameras on a single computer screen at one central location. Users can set up automated e-mail alerts
and be instantly informed of unusual activities. In addition, this network camera supports the universal plug-n-play feature, which allows computers running on
Windows 2000/XP/Vista to automatically recognize the camera and add it to the network. Sign up with one of the free Dynamic DNS services available on the web,
to assign a name and domain to the camera (e.g.mycamera.dlinkddns.com). This allows users to remotely access the camera without having to remember the IP
address.
1. Camera must be connected to a multicast-enabled router
Īpašības
NETWORK PROTOCOL SUPPORT
IPv4, TCP/IP, RTSP/ RTP/ RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS, PPPoE, IGMP, Samba client, IP Filtering, 3GPP
BUILT-IN NETWORK INTERFACES
+ 10/100BASE-TX Ethernet port, RJ45
VIDEO ALGORITHM SUPPORT
+ JPEG for still image
+ Compression: MJPEG & MPEG-4
+ Streaming: Simultaneous dualstreaming
+ MPEG-4 streaming over UDP, TCP, or HTTP
+ MPEG-4 multicast streaming
+ MJPEG streaming over HTTP
+ Supports 3GPP mobile surveillance
+ Camera live viewing for up to 10 clients
VIDEO RESOLUTION
+ MJPEG & MPEG-4 video with resolution up to 640x480 (VGA)
+ Up to 30fps at 176 x 144
+ Up to 30fps at 320 x 240
+ Up to 30fps at 640 x 480
VIDEO FEATURES
+ Adjustable image size, quality, and bit rate
+ Time stamp and text overlays
+ 3 configurable motion detection windows
+ Flip & mirror
+ Configurable brightness
+ AGC, AWB, AES
VIDEO BIT RATE
20K to 4M
SENSOR & LENS SPECIFICATIONS
+ SONY 1/4 inch progressive scan CCD sensor
+ Focal length: f=4.1mm to 73.8mm
+ F-number: F1.4 (wide), F3.0 (tele)
+ Iris: Auto/Manual (F1.4 to F22)
+ Removable IR-cut filter: Auto/Schedule/Manual
+ 18x optical zoom (4x digital zoom)
+ Angle of View: 48° ~ 2.8° (horizontal)
+ Shutter speed: 1/2 sec. to 1/10000 sec.
+ Minimum illumination: 1.61 Lux (F1.4,
1/30s), 0.38 Lux (F1.4, 1/30s, ICR ON)
EVENT MANAGEMENT
+ Motion detection weekly schedule
+ Event notification and upload snapshots/video clips via using HTTP, SMTP, or FTP
+ Multiple HTTP, SMTP, or FTP server setups
+ Multiple event notification setups for flexible application
+ Multiple recording methods for easier backup
AUDIO
+ Compression and bit rate:
GSM-AMR speech compression, bit rate: 4.75 kbps ~12.2 kbps
MPEG-4 AAC audio encoding, bit rate:
16 kbps ~128 kbps
+ Interface: Built-in microphone, external microphone input, external speaker output
+ Supports two-way audio by SIP protocol
+ Supports hardware and software audio mute
SECURITY
+ Administrator and user group protected
+ Password authentication
+ HTTP and RTSP digest encryption
SURVEILLANCE SOFTWARE FUNCTIONS
+ Remote management/control of up to 32 cameras
+ Viewing of up to 32 cameras on one screen
+ Supports all management functions provided in web interface
+ Scheduled motion triggered, or manual recording options
REMOTE MANAGEMENT
+ Configuration accessible via web browser
+ Take snapshots/video clips and save to CF card, local hard drive or NAS via web browser
SYSTEM REQUIREMENTS
+ Operating System: Microsoft Windows 2000, XP, Vista
+ Browser: Internet Explorer, Firefox, Netscape, Mozilla, Opera browser 3GPP Mobile Surveillance
+ Handsets with 3GPP player
+ Packet Video Player 3.0
+ QuickTime 6.5
+ Real Player 10.5
Ethernet Interface
+ IEEE 802.3 compliance
+ IEEE 802.3u compliance
+ Supports Full-Duplex operations
+ 802.3x Flow Control support for Full-Duplex mode
+ Supports IEEE 802.3af standard (PoE)
EXTERNAL DEVICE INTERFACE
+ One D/I and one D/O for external sensor and alarm
+ RS485 interface for external scanner
+ DC12V output for external accessory
DIAGNOSTIC LED
2 color LED
FRONT-END STORAGE
CF card slot for local recording of MP4 files
POWER INPUT
100-240Vac, 50/60Hz, 12Vdc, 1.25A
POWER CONSUMPTION
5.4W
DIMENSIONS
80 (W) X 143.5 (D) X 92.4 (H) (mm)
WEIGHT
1012 grams
OPERATION TEMPERATURE
0º to 40º C (32º to 104º F)
STORAGE TEMPERATURE
-20º to 70º C (-4º to 158º F)
HUMIDITY
20% to 80% non-condensing
CERTIFICATIONS
+ FCC Class B
+ CE
+ C-Tick
PACKAGE INCLUDES
+ DCS-3415 camera
+ External power adapter
+ Camera stand
+ Cat5 ethernet cable
+ Quick installation guide
+ Master CD
