Ātrā meklēšana
Produkta iespējas:
HD Day & Night Network Camera
EOL EOS
Apraksts:
High Resolution Surveillance
The D-Link DCS-3112 is a high-end HD Day & Night Network Camera, equipped with a 1/4” Megapixel Progressive Scan CMOS sensor and a 3.5-8 mm DC auto iris lens. The camera can capture HD video at resolutions of up to 1280 x 720/1280 x 1024 with frame rates up to 30 fps. Snapshots and video can be saved to a network drive, or to onboard storage through the built-in SD Card slot.
Multiple Video Streams
The DCS-3112 supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high-quality and bandwidth-efficient compression formats. MJPEG delivers excellent file integrity, ideal for situations which require high image detail. H.264 and MPEG-4 produce a small file size, useful for extended recording or for use in low-bandwidth networks. Additionally, the DCS-3112 supports multicast H.264 and MPEG-4 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network.
Flexible Connectivity
The DCS-3112 incorporates Power over Ethernet (PoE), which allows it to be easily installed in a variety of locations, even when no power outlet is nearby. The DCS-3112 also includes input and output ports that allow connectivity to external devices such as IR sensors, switches, and alarm relays. An RS-485 interface provides connectivity to an optional pan/tilt enclosure which effectively adds pan/tilt functionality to the DCS-3112. An additional 12 V interface provides power for an optional LED illuminator.
Smart And Easy To Use
The included D-ViewCam software allows you to view up to 32 cameras on a single computer screen from a central location. E-mail notifications can be sent whenever an event occurs, such as when motion is detected, if a camera is moved, or if a link to a camera is lost. Record snapshots and video automatically through motion-triggered recording, or according to a set schedule that you define.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
