Ātrā meklēšana
Produkta iespējas:
Full HD Day & Night Outdoor Network Camera
Īpašības:
Camera Hardware Profile
• 1/2.7" 2 Megapixel progressive CMOS sensor
• 30 meter IR illumination distance
• Minimum illumination: 0 lux with IR LEDs on
• Built-in Infrared-Cut Removable (ICR) Filter module
• 10x digital zoom
• Focal length: 4.3 mm
• Aperture: F2.0
• Angle of view:
  (H) 73.5°
  (V) 42.5°
  (D) 83.3°
Camera Housing
• IP-66 compliant weatherproof housing
• Cable management bracket
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable privacy mask zones
• Configurable shutter speed, brightness, saturation, contrast, and sharpness
Video Compression
• Simultaneous H.264/MPEG-4/MJPEG format compression
• H.264/MPEG-4 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 at 1920 x 1080 (up to 15 fps), 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 up to 30 fps
• 4:3 at 1440 x 1080 (up to 15 fps), 1280 x 960, 1024 x 768, 800 x 600, 640 x 480, 320 x 240, 176 x 144 up to 30 fps
Audio Support
• G.726
• G.711
External Device Interface
• 10/100 BASE-TX Fast Ethernet port with support for 802.3af PoE
• SD/SDHC card slot
• SD/SDHC card slot
• Audio input/output
• DI/DO Connector 12 V DC Output
Network Protocols
• IPv6
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP/HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP/RTSP/RTCP
• IP filtering
• QoS
• CoS
• Multicast
• IGMP
• ONVIF compliant
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP digest encryption
System Requirements for Web Interface
• Browser: Internet Explorer, Firefox, Chrome, or Safari
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive or NAS via web browser
• Configuration interface accessible via web browser
Operating System
• Windows 7/Vista/XP/2000
D-ViewCam™ System Requirements
• Operating System: Microsoft Windows 7/Vista/XP
• Web Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Remote management
• Control and manage up to 32 cameras
• View up to 32 cameras on one screen
• Management functions provided in web interface
• Scheduled motion triggered and manual recording
Fiziskie raksturlielumi
Weight
• 1.92 kg with bracket and sun shield
External Power Adapter
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 12 V, 1.25 A
Power Consumption
• 11.2 watts ± 5 %
Temperature
• Operating: -40° to 50°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• C-Tick
Dimensions
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
