Ātrā meklēšana
Produkta iespējas:
Wi-Fi Baby Camera Jr.
Īpašības:
Camera Hardware Profile
• 1/5” VGA CMOS sensor
• 5 meter IR illumination distance
• Minimum illumination: 0 lux with IR LED on
• Built-in microphone and speaker
• Digital zoom
• Adjustable angle and pivot
• Focal length: 2.44 mm
• Aperture: F2.4
• Angle of view:
  (H) 57°
  (V) 42°
  (D) 68°
External Device Interfaces
• 802.11n wireless
• Reset button
• Direct button
• Power port (Micro-USB)
LEDs
• Link/Activity/Power
• Cloud/Direct Mode
Image Features
• Configurable image size
• Time stamp overlay
Video Compression
• MJPEG format video compression
• JPEG for still images
Video Resolutions
• 640 x 480
• 320 x 240
Audio Support
• PCM
• 5 built-in lullabies
Baby Monitoring Features
• Sound detection with adjustable sensitivity
• Motion detection with adjustable sensitivity
• Sends notifications when sound or motion is detected
• 2-way audio lets you listen and respond to your child*
Mobile App
• mydlink Baby Camera Monitor app available on the App Store® and Google Play™
• Compatible with iPhone and iPad using iOS 5.1.1 or higher
• Compatible with Android smartphones and tablets using Android 4.1 or higher
Network Protocols
• IPv4
• ARP
• TCP/IP
• UDP
• ICMP
• DHCP client
• HTTP
• HTTPS (for configuration)
• UPnP port forwarding
Security
• Administrator protection
• Password authentication
• HTTP authentication
Fiziskie raksturlielumi
Dimensions (L x W x H)
• 70 x 75 x 100 mm
Weight
• 108.2 g
Power Input
• 5 V DC/1.2 A, 50/60 Hz power adapter, 5 V DC/1.5 A, 50/60 Hz power adapter for EU/UK
• Can be powered by an external USB battery with at least 2 A output
Power Consumption
• 4.4 watts max.
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• IC
• C-Tick
* 2-way audio is half-duplex.
** USB battery not included, requires at least 2 A output.
*** iOS version of the app only, feature will be available on Android version in future.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
