Ātrā meklēšana
Produkta iespējas:
HD Cube Network Camera
Īpašības:
Camera Hardware Profile
• 1/4” Megapixel progressive CMOS sensor
• 5 meter IR illumination distance
• Minimum illumination: 0 lux with IR LED on
• Built-in Infrared-Cut Removable (ICR) Filter module
• Built-in PIR sensor (5 meter)
• Built-in microphone and speaker
• 10x digital zoom
• Focal length: 3.45 mm
• Aperture: F2.0
• Angle of view:
  (H) 57.8°
  (V) 37.8°
  (D) 66°
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable privacy mask zones
• Configurable shutter speed, brightness, saturation, contrast, and sharpness
Video Compression
• Simultaneous H.264/MJPEG format compression
• H.264 multicast streaming
• JPEG for still images
Video Resolutions
• 16:9 - 1280x720, 800x448, 640x360, 480x272, 320x176 at frame rates up to 30 fps
• 4:3 - 960x720, 800x592, 640x480, 480x352, 320x240 at frame rates up to 30 fps
Audio Support
• G.711
• AAC
External Device Interfaces
• 10/100 BASE-TX Fast Ethernet port
• DI / DO  port
• MicroSD/SDHC card slot
Network Protocols
• IPv6, IPv4, TCP/IP, UDP, ICMP, DHCP client, NTP client (D-Link), DNS client, DDNS client (D-Link), SMTP client, FTP client
• HTTP / HTTPS, Samba Client, PPPoE, UPnP port forwarding, RTP / RTSP/ RTCP, IP filtering, QoS, CoS, Multicast, IGMP, ONVIF compliant
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP digest encryption
System Requirements for Web Interface
• Operating System: Microsoft Windows 8/7/Vista/XP/2000
• Browser: Internet Explorer, Firefox, Chrome
Event Management
• Motion detection
• Sound detection
• Event notification and upload snapshots/video clips via SMTP, or FTP
• Supports multiple SMTP, and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive
• Configuration accessible via web browser
D-ViewCam™ System Requirements
• Operating System: Microsoft Windows 7/Vista/XP
• Web Browser: Internet Explorer 6 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Remote management/control of up to 32 cameras
• Supports all management functions provided in web interface
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
Physical Parameters
Dimensions
• 128.6 x 82x 89 mm
Weight
• 116 grams
Power Supply
• PoE (802.3af Class 2) / 5 VDC, 1.2 A
Power Consumption
• 4.1 +/-5% watts(PoE)
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 90% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• C-Tick
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
