Ātrā meklēšana
Produkta iespējas:
5 Megapixel Day & Night Outdoor Network Camera
Īpašības:
Camera Hardware Profile
• 1/3.2” 5 Megapixel CMOS sensor
• 30 meter IR illumination distance
• Built-in Infrared-Cut Removable (ICR) Filter module
• Minimum illumination:
• 0.5 lux Color mode
• 0.1 lux Black and White mode
• 0 lux Black and White mode with IR LED on
• Minimum object distance 0.3 m
• 2.8 ~ 12 mm motorized zoom vari-focal DC iris lens
• Aperture F1.8
• Angle of view
• (H) 25.49° to 85.02°
• (V) 17.09° to 65.47°
• Shutter Speed: 1/2.5 ~ 1/10,000
• 4x digital zoom
Camera Housing
• IP66 compliant weatherproof housing
• Included sunshield
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• 3 configurable motion detection windows
• Tamper detection
• Configurable privacy mask zones
• Configurable exposure, brightness, saturation, contrast,
sharpness, white balance, WDR, flip and mirror
Video Compression
• Simultaneous H.264/MJPEG format compression
• H.264 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 1920x1080, 1280x720, 960 x 540 at up to 30 fps
• 4:3 - 2560x1920, 2048x1536, 1600x1200, 1280x960 at up to 15 fps
Audio Support
• AAC
• G.711
External Device Interfaces
• 10/100 BASE-TX Ethernet port with PoE
• 1 DI / 1 DO
• Reset button
• Video Out (BNC)
• microSD card Slot (SD/SDHC)
• Audio input / output
Network Protocols
• IPv6
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP / HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP / RTSP/ RTCP
• IP filtering
• QoS
• CoS
• Multicast
• ONVIF compliant
• SNMP
Security
• Administrator and user group protection
• Remote client access control
• HTTP and RTSP authentication
• HTTPS encryption for web access
System Requirements for Web Interface
• Browser: Internet Explorer 7 or higher, Firefox, or Safari
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple HTTP, SMTP, and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive
• Configuration interface accessible via web browser
OS Support (for setup utility)
• Operating System: Windows 8/7/Vista/XP/2000
D-ViewCamTM System Requirements
• Web Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
D-ViewCamTM Software Functions
• Remote management/control of up to 32 cameras
• Supports all management functions provided in web interface
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
Physical parameters
Weight
• 1.25 kg for camera only, without sunshield and mounting bracket
Power
• External power adapter: 12 V DC 1.5 A. 50/60 Hz
Power Consumption
• Max:12.48 W Temperature
• Operating: -40 to 50 ̊C
• Storage: -20 to 70 ̊C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• ICES-003
• FCC
• C-Tick
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
