Ātrā meklēšana
Produkta iespējas:
Vigilance Full HD Outdoor PoE Mini Dome Camera
Īpašības:
Device Interfaces
• 10/100 BASE-TX Ethernet port with PoE (802.3af) Class 2
Camera Hardware Profile
• 1/3” 2 Megapixel progressive CMOS sensor
• 20 meter IR illumination distance
• Minimum illumination:
  Color (Day Mode), IR LEDs off: 1.0 lux
  B/W (Night Mode), IR LEDs off: 0.5 lux
  B/W (Night Mode), IR LEDs on: 0 lux
• Built-in Infrared-Cut Removable (ICR) Filter module
• 10x digital zoom
• Minimum object distance 0.2 m
• Focal length: 2.8 mm
• Aperture: F2.0
• Angle of view (16:9):
  (H) 96°
  (V) 54°
  (D) 108°
• Adjustment angle (non-motorized):
  Tilt: 75°
  Pan: 360°
  Rotation: 360°
Camera Housing
• IP66 compliant weatherproof housing
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable privacy mask zones
• Configurable exposure time, brightness, saturation, contrast, sharpness
• Wide Dynamic Range (WDR)
• 3D filtering
Video Compression
• Simultaneous H.264/MJPEG format compression
• H.264/MJPEG multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1920 x 1080, 1280 x 720, 800 x 448, 640 x 360 up to 30 fps*
• 4:3 - 1440 x 1080, 1280 x 960, 1024 x 768, 800 x 592, 640 x 480 up to 30 fps*
Network Protocols
• IPv6
• IPv4
• ARP
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP/HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP/RTSP/RTCP
• IP filtering
• Multicast
• CoS
• QoS/DSCP
• SNMP
• ONVIF compliant
• Bonjour
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
System Requirements for Web Interface
• Operating system: Microsoft Windows 10/8/7 or Mac OS X 10.7 or higher
• Browser: Internet Explorer 8, Firefox 12, or Safari 6 or higher
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive
• Configuration interface accessible via web browser
D-ViewCamTM System Requirements
• Operating System: Microsoft Windows 10/8/7
• Web Browser: Internet Explorer 8 or higher
• Protocol: Standard TCP/IP
D-ViewCamTM Software Functions
• Remote management/control of up to 32 cameras
• Supports all management functions provided in the web interface
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
Physical Parameters
Weight
• 370 grams ± 5%
Dimensions
• Diameter: 113 mm
• Height: 85 mm
Power
• 12 V DC / 1.5 A, 50/60 Hz
• IEEE 802.3af PoE Class 2
Power Consumption
• 5.2 watts ± 5%
Temperature
• Operating: -40° to 50°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• C-Tick
* Frame rates when streaming video may vary depending on network conditions and method used.
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
