Ātrā meklēšana
Produkta iespējas:
2-Port USB 3.0 PCI Express Card
EOL EOS
Īpašības:
Interface
• PCI Express x1
• 2 downstream USB type a (female) ports
Standards
• USB specification version 3.0
• USB specification version 2.0
• USB specification version 1.1 1
• USB specification version 1.0
•ƒ OHCI (open Host Controller Interface)
•ƒ EHCI (Enhanced Host Controller Interface)
•ƒ PCI Express 2.0
Data rates
•ƒ SuperSpeed: 4.8 Gbps
•ƒ High Speed: 480 Mbps
•ƒ Full Speed: 12 Mbps
•ƒ Low Speed: 1.5 Mbps
Connectivity
Up to 127 devices by cascading multiple hubs
System requirements
• Windows® 7/vista/XP SP3 or higher
•ƒ Available PCI Express x1 slot
Supplied power
Maximum 900ma per port
Fiziskie raksturlielumi
Dimensions (l x W x H)
75.8 x 61.5 x 2.0 mm (2.98 x 2.42 x 0.08 inches)
Weight
43 grams
Operating temperature
0 to 40 °C (32 to 104 °F)
Storage temperature
-20 to 60 °C (-4 to 140 °F)
Operating humidity
0% to 80% (non-condensing)
Package contents
• D-link 2-Port USB 3.0 PCI Express Card
• Full-height bracket
• Half-height bracket
Certifications
• USB-IF
•ƒ WHQL
•ƒ FCC
•ƒ CE
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
