Produkta iespējas:
Wireless N PowerLine Gigabit Router |
Īpašības:
Minimum System Requirements
• Windows, Macintosh, or Linux-based operating system
• CD-ROM drive
• Ethernet Adapter
• Internet Explorer 6 or higher, Firefox 3.0 or higher, Safari 3.0 or higher, Google Chrome 2.0 or higher
Device Management
• Web UI
• SharePort™ Plus
• UPnP™ AV Media Server
• Web File Access
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.3u
• IEEE 1901
• HomePlug AV
Advanced Firewall Features
• VPN Pass-Through/Multi-sessions
• PPTP/L2TP/IPSec
Device Interfaces
• 4 10/100/1000Base-T Gigabit LAN ports (RJ-45)
• 1 10/100/1000Base-T Gigabit WAN port (RJ-45)
• 1 USB 2.0 port
Wireless Frequency Range
• 2.4 GHz to 2.4835 GHz
Data Rates
• PowerLine: up to 500 Mbps*
• 802.11n: up to 300 Mbps**
Antennas
• Two internal 2 dBi antennas
Security
• 64/128-bit WEP
• WPA and WPA2 (Wi-Fi Protected Setup)
SharePort™ Function Support
• Allows connection of external hard drive or multifunction printer to USB port
• Allows sharing of HD space, printing and scanning functions
LED Status Indicators
• Power
• Internet
• PowerLine
Physical Parameters
Power
• 100 V to 240 V
Power Consumption
• Max. 12 W
Operating Temperature
• 0°C to 40°C
Storage Temperature
• -20°C to 65°C
Operating Humidity
• 10% to 90%
Storage Humidity
• 5% to 95%
Certifications
• FCC
• UL
• CE
• Wi-Fi
• IPv6
* Maximum throughput based on theoretical transmission PHY rate. Actual data throughput will vary. Network conditions and environmental factors, including volume of traffic, network overhead, and maximum transmissions speeds of connecting products, may lower actual data throughput rate. Interference from devices that emit electrical noise, such as vacuum cleaners and hair dryers, may adversely affect the performance of this product. This product may interfere with devices such as lighting systems that have a dimmer switch or a touch-sensitive on/off feature, short-wave radios, or other PowerLine devices that do not follow the HomePlug AV standard.
** Maximum wireless signal rate derived from IEEE standard 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range
Fiziskie raksturlielumi |
Skatiet arī
