DWC-1000Projektiem
Wireless Controller
Apraksts
The D-Link DWC-1000 Wireless Controller is a centralized wireless LAN manager developed specifically for campuses, branch offices, and small-to-medium enterprises (SMBs). With the ability to manage up to six wireless access points (upgradable to 24) and a maximum of 96 wireless access points in a Controller Cluster, the DWC-1000 is a cost-effective mobility solution for small to medium-scale environments. Its auto-managed AP discovery and single point management allow customers to acquire an enterprise class system without the burden of executing massive and complex configurations. With a robust and comprehensive security detection system, the DWC-1000 also enables managed APs to
block potential attacks from unauthorized users and devices, especially for wireless environments.
Robust and Optimized Network
The DWC-1000 features a self-organizing, self- optimizing, and self-healing network capability to increase the stability of the entire wireless network. With regular-based radio scanning and performance analyzing, the DWC-1000 automatically adjusts radio channels and power periodically to avoid interference and keep the wireless network in an optimized state. To make up for a sudden RF signal vacuum created by any “dead” access point, the DWC-1000 will increase the transmit output power of neighboring access points to expand RF coverage.
Comprehensive Security
The DWC-1000 provides a comprehensive wireless security solution for any network. On the wireless side, empowered by a Wireless Instruction Detection System (WIDS), the DWC-1000 detects rogue access points and rogue clients as well as anticipates wireless threats, preventing any potential damage and illegal access. In addition to other fundamental
wireless security features including WEP, WPA Personal/Enterprise, WPA2 Personal/Enterprise, and MAC Authentication to determine the identity of wireless devices, the Captive Portal feature allows you to block clients from accessing the network until the clients verify their identities. This double-layer authentication and authorization provides a robust
security fence to also protect against attacks from within the network.
High Scalability, Availability, and Flexibility
Many companies are frequently changing in terms of size and organizational structure. To address such changing needs, the DWC-1000 offers a new dimension in feature selections: administrators can purchase a Business Wireless Plus license to upgrade the DWC-1000’s capabilities. D-Link offers two types of Business Wireless Plus licenses: an AP license upgrade and a VPN license upgrade.
The AP license upgrade increases the number of manageable access points. The DWC-1000 Wireless Controller manages up to six access points by default and after AP license upgrading, can manage up to 24 access points per controller.
The VPN license upgrade enables the DWC-1000 to provide VPN, Router, and Firewall functionality. The firewall function allows administrators to control network access by setting classification policies. The dual Option ports provide link failover and provide Internet connection redundancy to ensure Internet access. The virtual private network (VPN) features provide secure remote control to manage access points in branch offices. Site-to-site VPN tunnels use IP Security (IPSec) Protocol, Point-to-Point Tunneling Protocol (PPTP), or Layer 2 Tunneling Protocol (L2TP) to facilitate branch office connectivity through encrypted virtual links. In addition, the Secure Sockets Layer (SSL) VPN tunnels empower your mobile users by providing remote access to a central corporate database.
Simplified Management
Centralized remote control of managed access points provide a simple way to automatically discover compatible D-Link Wireless Access Points, add them into the managed access point list, and configure them with one-time configuration dispatch settings. With the controller clustering feature, the administrator can easily log into one wireless controller and perform essential configurations on others within the group. The real-time monitoring of access points and associated client stations enable the efficient utilization of network resources. System alarms and statistics reports on managed access points also help the administrator to use the DWC-1000 to manage, control, and optimize network performance.
Īpašības
Interface
• Ethernet:
  2 10/100/1000 option ports*
  4 10/100/1000 LAN ports
• USB: 2 USB 2.0 ports
• Console: RJ-45
Capacity and Performance
• Maximum Access Points per unit (default/upgrade): 6/24**
• Maximum Access Points per cluster (default/upgrade): 24/96**
• Concurrent Captive Portal authentication users (Wired/ Wireless): 124/ 400
• Dedicated IPSec VPN tunnels***: 70
• Dedicated PPTP/L2TP VPN tunnels***: 25
• Dedicated SSL VPN tunnels***: 20
Access Point Management
• Compatible Managed APs: DWL-8600AP, DWL-6600AP, DWL-3600AP
• AP Discovery & Control: Layer-2, Layer-3
• AP Monitoring:
  Managed AP
  Rogue AP
  Authentication Fail AP
  Standalone AP
• Client Monitoring:
  Authenticated Client
  Rogue Client
  Authentication Fail Client
  Ad-hoc Client
• Supports Centralized RF/Security Policy Management
Roaming
• Fast Roaming
• Intra-controller/Inter-controller roaming
• Intra-subnet/Inter-subnet roaming
Security
• Wireless Security:
  WEP
  Dynamic WEP
• Wireless Instruction Detection & Prevention System (WIDS):
  Rogue and Valid AP Classification
  Rogue AP Mitigation
• LAN Security: 802.1x port-based access control and guest VLAN
• Authentication:
  Captive Portal
  MAC Authentication
VLAN
• VLAN Group: up to 255 entries
• 802.1q VLAN Tagging
• Subnet-based VLAN
• Port-based VLAN
Firewall System***
• Policy:
  Each feature supports 100 rules
  Supports up to 600 firewall rules
• Dynamic Route: RIPv1, RIPv2
• Dynamic DNS
• NAT, PAT
• Web Content Filtering:
  Static URL
  Keywords
Networking***
• Route Failover
• Outbound Load Balancing
Virtual Private Network (VPN)***
• Encryption Methods: DES, 3DES, AES, Twofish, Blowfish, CAST-128, NULL
• IPSec NAT Traversal
• Dead Peer Detection
• IP Encapsulating Security Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
SSL Virtual Private Network (SSL VPN)***
• SSL Encryption Methods: DES, 3DES, AES
• SSL Message Integrity: MD5, SHA1
System Management
• Web-based User Interface: HTTP
• Command Line Interface
• SNMP: v1, v2c, v3
Sertifikāti
Informācija pasūtījumam
Available licenses*
DWC-1000-AP18-LIC    License for supporting 18 additional APs on DWC-1000
DWC-1000-AP6    License for supporting 6 additional APs on DWC-1000
DWC-1000-VPN    License for supporting VPN functions on DWC-1000
DWC-1000-WCF    License for supporting Web Content Filter functions on DWC-1000
*For update license device MUST be registered at register.dlink.com
Attēli
DWC-1000/А1
View from the right
Back view
DWC-1000/С1
View from the right
View from the right
Back view
Pārlādēt
Skatiet arī
