Ātrā meklēšana
Produkta iespējas:
Unified N Concurrent Dual-band PoE Access Point
Īpašības:
System
• Wi-Fi Interface: 802.11a/b/g/n 2.4/5.0GHz
• LAN Interface: 10/10/100 Gigabit Ethernet
• Console: RJ-45
• Antenna: 2x2 MIMO embedded antenna with 4 external antenna connectors
• Power Method: IEEE 802.3af Power Over Ethernet or external power adapter
Wireless Frequency
• 802.11n: 2.4 to 2.497GHz and 4.9 to 5.85GHz
• 802.11b/g: 2.4 to 2.4835GHz
• 802.11a: 5.15 to 5.35GHz and 5.725 to 5.825GHz
Data Transfer Rate
• 802.11n:
  6.5 to 130 Mbps (20MHz)
  6.5 to 300 Mbps (40MHz)
• 802.11a/g: 54, 48, 36, 24, 18, 12, 9, and 6 Mbps
• 802.11b: 11, 5.5, 2, and 1 Mbps
The Output Power of Transmitter
• 802.11a/g: 11 (+/-2) dBm at 54, 48, 36, 24, 18, 12, 9 and 6 Mbit/s
• 802.11b: 13 (+/-2) dBm at 11, 5.5, 2 and 1 Mbit/s
• 802.11n (2.4GHz/HT-20): 11 dBm at MCS0/8, MCS1/9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
• 802.11n (2,.4GHz/HT-40): 11 dBm at MCS0/8, MCS1/9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
• 802.11n (5GHz/HT-20): 11 dBm at MCS0/8, MCS1/9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
• 802.11n (5GHz/HT-40): 11 dBm at MCS0/8, MCS1/9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
Receiver Sensitivity
• 802.11a
  -86 (+/-2) dBm at 6 Mbit/s
  -86 (+/-2) dBm at 9 Mbits/s
  -84 (+/-2) dBm at 12 Mbit/s
  -81 (+/-2) dBm at 18 Mbit/s
  -77 (+/-2) dBm at 24 Mbit/s
  -75 (+/-2) dBm at 36 Mbit/s
  -68 (+/-2) dBm at 48 Mbit/s
  -67 (+/-2) dBm at 54 Mbit/s
• 802.11b
  -92 (+/-2) dBm at 1 Mbit/s
  -90 (+/-2) dBm at 2 Mbit/s
  -88 (+/-2) dBm at 5.5 Mbit/s
  -85 (+/-2) dBm at 11 Mbit/s
• 802.11g
  -87 (+/-2) dBm at 6 Mbit/s
  -87 (+/-2) dBm at 9 Mbits/s
  -85 (+/-2) dBm at 12 Mbit/s
  -82 (+/-2) dBm at 18 Mbit/s
  -79 (+/-2) dBm at 24 Mbit/s
  -76 (+/-2) dBm at 36 Mbit/s
  -71 (+/-2) dBm at 48 Mbit/s
• 802.11n
  2.4GHz/HT-20
  -85dBm at MCS0/8
  -82dBm at MCS1/9
  -80dBm at MCS2/10
  -77dBm at MCS3/11
  -74dBm at MCS4/12
  -69dBm at MCS5/13
  -68dBm at MCS6/14
  -65dBm at MCS7/15
  2.4GHz/HT-40
  -82 DBm at MCS0/8
  -79 DBm at MCS1/9
  -77 DBm at MCS2/10
  -74 DBm at MCS3/11
  -71 DBm at MCS4/12
  -66 DBm at MCS5/13
  -65 DBm at MCS6/14
  -62 DBm at MCS7/15
  5GHz/HT-20
  -85dBm at MCS0/8
  -79dBm at MCS1/9
  -77dBm at MCS2/10
  -74dBm at MCS3/11
  -70dBm at MCS4/12
  -66dBm at MCS5/13
  -65dBm at MCS6/14
  -64dBm at MCS7/15
  5GHz/HT-40
  -79 DBm at MCS0/8
  -76 DBm at MCS1/9
  -74 DBm at MCS2/10
  -71 DBm at MCS3/11
  -67 DBm at MCS4/12
  -64 DBm at MCS5/13
  -63 DBm at MCS6/14
  -62 DBm at MCS7/15
Security
• SSID: 16 SSID per frequency band, 32 SSID per AP Station Isolation
• Wireless Security: WEP, Dynamic WEP, WPA Personal/ Enterprise, WPA2 Personal/ Enterprise
• Detection & Prevention: Rogue and Valid AP Classification
• Authentication: MAC Address Filtering, 802.1X
System Management
• Web-based User Interface: HTTP/HTTPS
• Command Line: SNMP, SSH, Telnet
Fiziskie raksturlielumi
Power
• Power Adapter: 12V/1A
• Power over Ethernet: 48V DC +/-10%
Enclosure Type
• PC or plenum-rated chassis
Enclosure Size
• 77.5 x 156mm
Weight
• 0.5kg
Operating Temperature
• 0 to 40°C
Operating Humidity
• 10% to 90% non-condensing
MTBF
• 497,476 hours
Safety
• cUL, LVD (EN60950-1), UL2043
EMI/EMC/RF
• FCC Class B, CE Class B, C-tick, IC, VCCI, NCC, TELEC, Wi-Fi Certified
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
