Ātrā meklēšana
Produkta iespējas:
8.5 dBi Pico Cell Patch Antenna
EOL
Apraksts:
The D-Link ANT24-0801 is a Pico Cell Patch Antenna for wireless data transmission in indoor or outdoor environments. The ANT24-0801 provides 8.5dBi signal strength operating on 2.4~2.5 GHz ISM band (Industrial, Scientific and Medical). This provides wider range of wireless coverage to reduce the cost of running standard cable lines.
The ANT24-0801 is a convenient way to extended wireless coverage to an existing 802.11b wireless LAN network. The ANT24-0801 can be used with the DWL-900AP+ wireless access point, DI-614+ wireless router, DI-714P+ wireless router, DWL-900AP wireless access point, DI-714 wireless router and the DI-713P wireless router Rev C1 or later wireless broadband router. The ANT24-0801 is weatherproof and made of corrosion-resistant material to withstand harsh outdoor conditions.
The D-Link ANT24-0801 includes a swivel mount that allows pivotal adjustment for precise positioning for the most concentrated signal strength. The D-Link ANT24-0801 includes a Lightning Surge Protector and 3 meters of Extension cable*.
* Users may use longer cables but signal strength will weaken after 1.6 feet.
Note: This product does not currently work with the enterprise DWL-1750 wireless router and the DWL-1700AP wireless access point.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
